[问题求助] 请高手赐教
P:2008-02-03 13:48:23
请教Infini-Band电线的相关资料
JTAC - Joint Technical Advisory Committee接头技术咨询委员会 (0) 投诉
P:2008-02-03 15:51:35
楼上是要请教问题呢还是请求资料?
chinese-finger - 电缆夹头 (0) 投诉
P:2008-02-08 00:58:06
請參考
An universal specification designed to replace SCSI I/O cable and for use as intracabinet disk drive cables. The performance for the following technologies:
  • Fibre Channel ( 1.0625GHZ,2.125GHZ )
  • Gigabit Ethernet 1000 BASE-CX,IEEE802.3 (1.25GHZ,2.5GHZ )
  • Storage Sub-systems
  • Telecom Equipment
The cable assembly must provide a minimum 400mV EYE pattern at the receiver end regardless of cable assembly length.
<DIV align=center>Cable length</DIV><DIV align=center>1M</DIV><DIV align=center>2M</DIV><DIV align=center>3M</DIV><DIV align=center>4M</DIV><DIV align=center>5M</DIV><DIV align=center>7M</DIV><DIV align=center>10M</DIV>
<DIV align=center>AWG</DIV><DIV align=center>24,28</DIV><DIV align=center>24,28</DIV><DIV align=center>24,28</DIV><DIV align=center>24</DIV><DIV align=center>24</DIV><DIV align=center>24</DIV><DIV align=center>24</DIV>
<DIV align=center></DIV><DIV align=center></DIV><DIV align=center></DIV>
<DIV align=left>HSSDCII 7pin male/HSSDCII 7pin male (28AWG) cable ass'y</DIV><DIV align=left>HSSDCII 7pin male/HSSDCII 7pin male (24AWG) cable ass'y</DIV><DIV align=center></DIV>
Fibre Channel & Infiniband Connector
HSSDC8 female P.C.B mounted with metal shieldingHSSDC7 female P.C.B mounted with metal shielding
Side Key: Fibre Channel
Center Key: Infiniband
FCH3 pin male right angle vertical SMD type for P.C.B mounted
SFP cage and 20 pin SMD connector
acrylonitrile-butadiene rubber - 丁腈橡胶 (0) 投诉
P:2009-01-16 13:49:41
谢谢
trial-and error experiment - 逐次逼近试验法,反复试验逼近法 (0) 投诉
