首页 > 国外线缆
[问题求助] 求助UL1110电线的标准
P:2008-01-25 14:01:51
有达人知道不?
在线等达人解答
integrated frequency router - 综合频率路由器 (0) 投诉
P:2008-01-25 14:14:18
UNDERWRITERS LABORATORIES INC.              APPLIANCE WIRING MATERIAL
Subj. 758     Section 1     Page 1110        Issued:  May 1, 1959
                                  Revised:  Oct. 25, 2000
Style 1110    Thermoplastic (PVC) - Insulated and Jacketed Wire.
______________________________________________________________________________
Rating     105°C, 300 VAC or 600 VDC.
*Conductor    No. 26-16 AWG, solid or stranded, tinned or bare.
Insulation    PVC or Labeled irradiated PVC, single (or complies
           with Manufacturer's AWM procedure) 15 mils min
           avg., 13 mils min. at any point, suitable for 105°C.
*Shielding    Optional.
Jacket     PVC, 15 mils min. avg., 13 mils min. at any
           point, compounds suitable for use at 105°C.
*Standard     Appliance Wiring Material UL 758.
Instructions  Detailed Examination.
to UL         Tensile Strength and Elongation of Insulation
*Representative      and Jacket, same as for Class 43.
*          Spark Test.
UL         (4)  Detailed Examination.
Counter-Check     (4)  Tensile Strength and Elongation of Insulation
*Program           and Jacket.
*          (4)  Heat Shock.
           (4)  Deformation, Class 43.
*          (4)  Cold Bend.
*          (4)  Horizontal Flame Test.
*Marking      General.
Use        For use in electronic equipment.
Tube extrusion - 管材挤出,挤压式,管材挤压,有底筒形件挤压加工 (0) 投诉
P:2008-01-25 14:20:52
请问有无PDF文档版本的..
empty drum - 空线盘;空盘 (0) 投诉
P:2008-01-25 15:46:43
這個你可以直接在UL網站上下載的...
fan - 风扇,鼓风机 (0) 投诉
