[问题求助] 谁知道 UL1360 20AWG 的详细规格
P:2008-01-16 16:23:46
誰知道  UL1360 20AWG 的詳細規格?
請求大家告知
謝謝
intelligent layer - 智能层 (0) 投诉
P:2008-01-16 16:26:35
你直接进入UL网站,查UL活页就可以了
in-line drying unit - 在线干燥装置 (0) 投诉
P:2008-01-16 16:34:06
UNDERWRITERS LABORATORIES, INC.                 FACTORY INSPECTION PROCEDURE
Subj.  758           Section   1        Page    1360   Issued  6-29-64
Vol.              This Page Effective                  Revised
  Style 1360        Thermoplastic (PVC) - Insulated wire for use
                    in Refrigerator Mullion Heating.
  Rating            105 C, 300 Volts.
  Conductor         One (1) mil diameter resistance wire wound
                    for a minimum of 25 turns per inch on a Rayon,
                    Cotton, Fortisan, Fiberglas, Dacron, or
                    Cordura yarn core.
  Insulation        Nominal 1/32 Inch wall of Thermoplastic (PVC)
                    compound suitable for use at 105 C.
  Covering          Extruded Zytel 33 nylon with 2 Mil minimum
                    thickness.
  Standard          Flexible Cord and Fixture Wire.
  Instructions      Detailed examination.
    to              Tensile strength and elongation of insulation,
  Inspector         Class 12.
                    Spark Test, 6000 Volts, page 30.
  Chicago           (4)  Detailed examination
  Counter-Check     (4)  Tensile strength and elongation of insulation,
  Program                page 33.
                    (4)  Heat Shock, page 37.
                    (4)  Deformation , page 38.
                    (4)  Cold Bend, page 39.
                    (2)  Flame Test, page 31.
  Marking           General, page 13.
                    Manufacturer's marker required, pages 3, 18, 19.
                    Items 2a, 2i, and where the nylon is transparent
                    3k, 4n.
                    Temperature marker required, pages 19, 20.
                    Items 7a, 7i, and where the nylon is transparent,
                    8k, 9k, 10n.
  Use               For Refrigerator Mullion Heating where
                    not subjected to repeating flexing in use.
江南狼 奖励 0 金币,.05 声望,于 2008-1-16 18:51:31 原因:谢谢!
monitor core - 监视线芯 (0) 投诉
P:2008-01-16 16:38:58
謝謝大家
哪位是否可以把1360 所在UL的網址告訴我!
非常感謝
cable number - 电缆号码;电报号码 (0) 投诉
P:2008-01-17 15:55:01
www.ul.com
railway telecommunication cable - 铁道通信电缆 (0) 投诉
