首页 > 国外线缆
[问题求助] 请问各位专家:awm2919是什么样的一种线呀?
P:2007-12-24 12:10:43
温度,额定压力,导体尺寸和材料,绝缘层材料和厚度,铠装材料和厚度(如有),对屏蔽或外护套的描述,所需的标志以及对其适用范围的叙述。
里面的芯线与普通的高温线AF-1相比,有什么不同吗?能否用高温线外加屏蔽网来代替?
[awm2919 在 2007-12-24 12:13:04 编辑过]
drum-lifting jack - 电缆盘升降用千斤顶 (0) 投诉
P:2007-12-24 12:50:07
UNDERWRITERS LABORATORIES INC.               APPLIANCE WIRING MATERIAL
Subj. 758       Section 2       Page 2919        Issued:  1978-03-22
                                    Revised:  2005-04-18
Style 2919
Low Voltage Computer Cable.
Rating
80°C, 30 Volts.
Insulated Conductors
No. 40 AWG minimum.  Labeled or complying with Manufacturer’s AWM Procedure having a minimum rating of 80°C, 30 V.
Assembly
Consists of two or more conductors, twisted pairs or groups of twisted conductors twisted together.  The conductors or groups of conductors may be laid parallel forming a flat, oval or round cable.  The lay of the conductors is not specified.  A barrier layer and/or fillers are optional.  Manufacturer shall maintain a complete description of each assembly.  May use same or mixed AWG size.
Covering
(Optional) - A 6 mil or heavier PVC covering may be extruded over the conductor assembly.
Shield
Optional.
Jacket
PVC - Class 43
                   THICKNESS (MILS)
#Dia of cable
under jacket         Minimum            Minimum
in inches            Average          at any point
0.425 or less            30                24
0.426 - 0.700            45                36
0.701 - 1.000            60                48
1.000 - 1.500            80                64
1.501 - 2.500           110                88
2.501 and larger        140               112
# - Major dia if cable is flat or oval.
Braid
Optional.
Standard
Appliance Wiring Material UL 758.
                                (Continued on Page 2919A)
Subj. 758       Section 2       Page 2919A       Issued:  1978-03-22
                                    Revised:  2003-02-17
Instructions
to UL
Representative
Detailed Examination.
Tensile Strength and Elongation of Jacket.
The designation of all Styles of the individual conductors
used making up the cable assembly shall be available, and
the UL Representative’s tag shall indicate if the Style is
labeled or not.  If they are not labeled, the appropriate
Follow-Up Tests shall be conducted.
UL
Counter-Check
Program
(4)  Detailed Examination.
(4)  Tensile Strength and Elongation of Jacket.
(4)  Heat Shock on Jacket.
(4)  Deformation on Jacket.
(4)  Cold Bend on Completed Cable.
(12) Cable Flame Test on Completed Cable.
If the insulated Styles are not labeled, the appropriate Follow-Up Tests shall be conducted.
Marking
General.
Use
As internal wiring or external interconnection in Class 2 Circuits of electronic computers and electric business machines.
SSTP cable - 屏蔽-屏蔽对绞电缆 (0) 投诉
P:2007-12-24 22:54:25
电脑周边线,型号很多。
sensor technology - 传感技术 (0) 投诉
P:2007-12-25 11:45:24
没有什么特别的,就是一款外观要求比较好的屏蔽线材,外被那么厚,押出很不错的。
filamentary superconductor - 细线超导体,多股细线超导体 (0) 投诉
P:2007-12-25 17:06:55
就是RGB 的一种,发泡是28AWG的,有中被。射线为26AWG,通常有6,7,8,9条。外被一般是7.4mm左右.
inorganic non-matellic material - 无机非金属材料 (0) 投诉
P:2009-10-30 16:05:40
就是低电压电脑线啊
AFWF - Augmented Fresh Water Fog增强的新鲜水雾 (0) 投诉
P:2021-07-03 10:23:59
RS-485通讯电缆(3x2x24AWG通讯电缆)阻燃 多股铜芯(7/0.20)聚乙烯绝缘聚氯乙烯护套,铝塑复合带+外镀锡铜网编织(密度≥80%)钢丝铠装。
integrated catalyst - 综合催化剂,综合催化器 (0) 投诉
