首页 > 标准共享
[国外标准] UL 1581 的标准
P:2007-12-19 13:54:13
搜索了一下下载UL1581标准都要威望值,哪位有不需要威望值的贡献一下吧,万分感谢!
我的邮箱是mtteng6@gmail.com
可以直接发到我邮箱里,谢谢!
cotton wrapping head - 纱包头,扎纱头 (0) 投诉
P:2007-12-19 14:13:54
你可以在论坛里找啊
ultra-short wave - 超短波 (0) 投诉
P:2007-12-19 14:16:00
论坛里的都要威望值,我没有啊。
short circuit capability - 短路容量 (0) 投诉
P:2007-12-19 14:20:54
UNDERWRITERS LABORATORIES INC.                    APPLIANCE WIRING MATERIAL
Subj. 758         Section 1       Page 1581         Issued:  Jan. 19, 1973
                                    Revised:  Nov. 15, 2000
Style 1581      Polyvinyl Chloride Insulated Wire.
______________________________________________________________________________
Rating      80°C, 300 V.
*Conductor      Nos. 15-10 AWG, solid or stranded, tinned or bare copper.
Insulation      Polyvinyl Chloride, 16 Mils minimum average 13 mils minimum             at any point, compounds suitable for use at 80°C in air and
            60 or 80°C in oil.
*Standard       Appliance Wiring Material UL 758.
Instructions    Detailed Examination.
to UL           Tensile Strength and Elongation of Insulation,
*Representative    same as for Class 43.
*           Spark Test, 3,000 Volts.
UL          (4)  Detailed Examination.
Counter-Check   (4)  Tensile Strength and Elongation of Insulation.
Program                      *
*           (4)  Heat Shock.
*           (4)  Cold Bend.
*           (4)  Horizontal Flame Test.
*           (4)  Deformation. ______________________________________________________________________________
*Marking        General.
Use         Internal wiring of Appliances where exposed to temperatures             exceeding 80°C and where not subjected to mechanical
            abuse or Internal Wiring of Appliances where exposed to
            temperatures not exceeding 80°C or where exposed to oil at a            temperature not exceeding (60°C or 80°C, which­ ever is
            applicable) and where not subjected to mechanical abuse.
            Tags may indicate the following:  00 Volts Peak - For
            Electronic Use Only.
lay-plate - 分线板 (0) 投诉
P:2007-12-19 14:52:34
这好像不是标准吧
drum-emptying device - 料桶排空装置(安装在塑料颗粒定量系统上) (0) 投诉
P:2007-12-19 15:00:03
有好多版本,你需要是什么版的?中文英语?最新的?
International Standards organization - 国际标准组织 (0) 投诉
P:2007-12-19 15:04:58
最好是中文的,英文的也可以。
reel-to-reel changeover - 换盘,更换线盘 (0) 投诉
P:2007-12-19 15:51:16
我有中文版的.
save energy - 节能 (0) 投诉
P:2007-12-20 08:37:23
我有UL1581-2001中文版
[aiceheart 在 2007-12-20 8:40:18 编辑过]
air-patented rod - 空气淬火线杆,空气冷却线杆 (0) 投诉
P:2007-12-20 08:41:08
为什么看不到上传的附件
grounding cable - 接地电缆 (0) 投诉
P:2007-12-23 19:53:12
看看,你能不能下我这是免费的,如果下不了请发邮件给我:yekyiimfengzi@tom.com
screened-conductor cable - 屏蔽导体电缆,屏蔽电缆 (0) 投诉
P:2007-12-24 07:43:50
我这里有一份看用不用得上?
small-pair-count telephone cable - 小对数电话电缆 (0) 投诉
P:2008-03-01 22:16:16
8楼的,能否传一份到我的邮箱hwq290@sohu.com,谢谢!
tps - terminals per station每站终端数,终端/站 (0) 投诉
P:2008-03-03 13:59:50
我想你們是要 檢驗標准UL1581吧﹐我這里有最新版的
fibre optic safety guide - 光纤安全导则 (0) 投诉
P:2008-03-06 17:23:04
我发了一份中文版的在技术资料区.你可以查找下载.
scanning - 扫描;检测 (0) 投诉
23
