首页 > 标准共享
[国外标准] UL1330 Extruded Fluorinated Ethylene Propylene Insulated Wire
P:2007-12-10 22:59:19
谁有UL1330请上传
confidence limit - 置信区间,置信界线 (0) 投诉
P:2007-12-11 08:37:59
我有,希望能帮到你.
videotex - 可视图文,可视数据,信息传视系统 (0) 投诉
P:2007-12-11 10:11:39
UNDERWRITERS LABORATORIES INC.              APPLIANCE WIRING MATERIAL
Subj. 758     Section 1     Page 1330        Issued:  1963-02-04
                                     Revised:  2003-04-14
Style 1330    Extruded Fluorinated Ethylene Propylene Insulated Wire.
______________________________________________________________________________
Rating     200 deg. C, 600 V.
Conductor     Nos. 30-4/0 AWG, solid or stranded, Sec. 5.
Insulation    Extruded fluorinated ethylene propylene
                       Insulation Thickness in Mils
           Conductor Size      Minimum        Minimum at
               AWG      Average        any Point
             30 - 10          20         18
              9 - 2           30         27
              1 - 4/0         45         40
Covering      (Optional) - FEP, 10 mils or heavier or glass braid
           7 mils or heavier.
Standard      Appliance Wiring Material UL 758.
Instructions  Detailed Examination.
to UL         Tensile Strength and Elongation of Insulation,
Representative       before aging.
           Spark Test.
UL         (4)  Detailed Examination.
Counter-Check (4)  Tensile Strength and Elongation of Insulation.
Program       (4)  Heat Shock.
           (4)  Cold Bend.
           (12) Horizontal Flame Test.
Marking       General.
Use        Internal Wiring of Appliances.
           In addition, the tag may also indicate the
           following: Suitable for immersion in gasoline;
           gasoline vapor; and 80 deg. C in oil.
IW - immediate window即现窗口 (0) 投诉
P:2007-12-11 12:52:42
太少了!
low velocity cloud - 低速云状物(如静电流化床涂敷设备中产生的带电颗粒云,散落时涂敷在电缆表面上) (0) 投诉
