首页 > 型号析疑 产品报价
[型号解析] 常用电缆规格(BV BLV BVR)
P:2007-12-07 21:17:50
收集整理了一下,常用电缆的规格,希望对需要的朋友有所帮助!
| <DIV align=center>常用线缆规格(BV BLV BVR)</DIV> | ||||
| 截面m㎡ | 最大直径 | 铝A | 铜A | |
| 2.5 | 3.9 | 17 | 31.6 | |
| 4 | 4.4 | 22 | 47.5 | |
| 6 | 4.9 | 29 | 67.1 | |
| 10 | 7 | 62 | 119 | |
| 16 | 8 | 78 | 179 | |
| 25 | 10 | 118 | 281 | |
| 35 | 11.5 | 156 | 381 | |
| 50 | 13.2 | 215 | 521 | |
| 70 | 15 | 282 | 734 | |
| 95 | 17.5 | 386 | 962 | |
| 120 | 19 | 431 | 1180 | |
| 150 | 21 | 539 | 1470 | |
| 185 | 23.5 | 666 | 1810 | |
| 240 | 26.5 | 857 | 2350 | |
| 300 | 29.5 | 1070 | 2930 | |
| 400 | 33 | 1390 | 3870 | |
| BV 聚氯乙烯铜线 BLV 聚氯乙烯铝线 | ||||
| BVR 铜软线 BV-105 铜105℃ | ||||
| BVV 铜线(潮湿环境高防护)BXF 橡皮绝缘铜线 | ||||
| BLXF 橡皮绝缘铝线 BLVV 铝线(潮湿环境高防护) | ||||
degree of water swelling - 水膨胀量 (0) 投诉
P:2007-12-07 21:19:23
<DIV align=center>VV29-铜芯聚氯乙烯绝缘钢带铠装聚氯乙烯护套电力电缆 </DIV><DIV align=center>VLV29铝芯聚氯乙烯绝缘钢带铠装聚氯乙烯护套电力电缆</DIV><DIV> </DIV><DIV>
</DIV>
| 标称面积m㎡ | 线芯结构no/mm | 绝缘厚度mm | 护套厚度mm | 计算外径mm | 环境25℃时载流量(A)空气敷设 | 环境25℃时载流量(A)埋土敷设 | 成品近似重量 kg/km | |||
| 铜芯 | 铝芯 | 铜芯 | 铝芯 | 铜芯 | 铝芯 | |||||
| 1*10 | 7*1.35 | 1.0 | 1.6 | 13.4 | 80.6 | 61.5 | 103.9 | 79.0 | 346 | 285 |
| 1*16 | 7*1.70 | 1.0 | 1.6 | 14.5 | 106.0 | 81.5 | 126.7 | 104.9 | 436 | 336 |
| 1*25 | 7*2.14 | 1.2 | 1.6 | 16.3 | 143.1 | 110.2 | 181.3 | 138.7 | 569 | 414 |
| 1*35 | 7*2.52 | 1.2 | 1.6 | 17.7 | 173.8 | 133.6 | 220.5 | 169.6 | 696 | 480 |
| 1*50 | 19*1.78 | 1.4 | 1.8 | 19.8 | 217.3 | 167.5 | 270.3 | 208.8 | 918 | 605 |
| 1*70 | 19*2.14 | 1.4 | 1.8 | 19.8 | 268.2 | 206.7 | 331.8 | 255.5 | 1272 | 783 |
| 1*95 | 19*2.52 | 1.6 | 2.0 | 22.0 | 329.7 | 253.4 | 394.3 | 304.2 | 1622 | 1036 |
| 1*120 | 37*2.03 | 1.6 | 2.0 | 26.2 | 377.4 | 292.6 | 454.7 | 350.7 | 1902 | 1162 |
| 1*150 | 37*2.25 | 1.8 | 2.0 | 28.4 | 434.6 | 335.0 | 518.3 | 398.6 | 2274 | 1355 |
| 1*185 | 37*2.52 | 2.0 | 2.2 | 30.9 | 494.0 | 380.5 | 580.9 | 447.3 | 2729 | 1582 |
| 1*240 | 61*2.25 | 2.2 | 2.2 | 33.6 | 584.0 | 449.4 | 676.3 | 521.5 | 3339 | 1853 |
| 1*300 | 61*2.52 | 2.4 | 2.6 | 37.0 | 669.9 | 515.2 | 760.0 | 584.1 | 4045 | 2073 |
all plastic fiber - 全塑光纤,全塑料光纤 (0) 投诉
P:2007-12-07 21:20:51
| 2*4 | 2*1*2.25 | 0.8 | 1.6 | 15.4 | 38.2 | 28.6 | 47.7 | 37.1 | 385 | 335 |
| 2*6 | 2*1*2.76 | 1.0 | 1.6 | 17.2 | 47.7 | 37.1 | 59.4 | 45.6 | 480 | 403 |
| 2*10 | 2*7*1.35 | 1.0 | 1.8 | 20.5 | 63.6 | 48.8 | 77.4 | 59.4 | 661 | 538 |
| 2*16 | 2*7*1.7 | 1.0 | 1.8 | 23.5 | 85.7 | 65.7 | 106.0 | 80.6 | 998 | 797 |
| 2*25 | 2*7*2.14 | 1.2 | 2.0 | 27.2 | 112.4 | 85.7 | 138.7 | 106.0 | 1330 | 1019 |
| 2*35 | 2*7*2.52 | 1.2 | 2.2 | 29.9 | 135.7 | 104.9 | 166.4 | 128.3 | 1631 | 1192 |
| 2*50 | 2*18*1.9 | 1.4 | 2.0 | 27.3 | 169.6 | 130.4 | 202.5 | 155.6 | 1775 | 1166 |
| 2*70 | 2*18*2.25 | 1.4 | 2.2 | 30.3 | 208.8 | 161.1 | 247.0 | 190.8 | 2272 | 1419 |
| 2*95 | 2*24*2.25 | 1.6 | 2.2 | 33.7 | 254.4 | 196.1 | 294.7 | 226.8 | 2878 | 1718 |
| 2*120 | 2*24*2.55 | 1.6 | 2.6 | 36.7 | 294.7 | 227.9 | 339.2 | 261.8 | 3477 | 2012 |
| 2*150 | 2*45*2.07 | 1.8 | 2.6 | 39.7 | 338.1 | 260.7 | 382.7 | 293.6 | 4175 | 2346 |
| 3*4 | 3*1*2.25 | 0.8 | 1.6 | 16.0 | 32.9 | 24.4 | 41.3 | 31.8 | 444 | 370 |
| 3*6 | 3*1*2.76 | 1.0 | 1.6 | 18.0 | 41.3 | 31.8 | 51.9 | 40.3 | 564 | 454 |
| 3*10 | 3*7*1.35 | 1.0 | 1.8 | 22.2 | 55.1 | 42.4 | 70.0 | 54.1 | 937 | 753 |
| 3*16 | 3*7*1.7 | 1.0 | 2.0 | 25.0 | 75.3 | 57.2 | 92.2 | 71.0 | 1229 | 128 |
TRC - temperature recording controller温度记录控制器 (0) 投诉
P:2007-12-07 21:21:41
| 3*25 | 3*7*3.14 | 1.2 | 2.0 | 28.6 | 101.8 | 77.4 | 121.9 | 93.3 | 1643 | 1176 |
| 3*35 | 3*7*2.52 | 1.2 | 2.2 | 31.4 | 120.8 | 93.3 | 147.3 | 113.4 | 2251 | 1599 |
| 3*50 | 3*18*1.9 | 1.4 | 2.2 | 31.2 | 152.6 | 117.7 | 182.3 | 141.0 | 2432 | 1619 |
| 3*70 | 3*18*2.25 | 1.4 | 2.6 | 35.0 | 189.7 | 146.3 | 236.4 | 171.7 | 3153 | 1872 |
| 3*95 | 3*24*2.25 | 1.6 | 2.6 | 38.8 | 230.0 | 177.0 | 261.8 | 201.4 | 4027 | 2287 |
| 3*120 | 3*24*2.55 | 1.6 | 2.6 | 41.5 | 267.1 | 205.6 | 299.9 | 231.1 | 4819 | 2622 |
| 3*150 | 3*45*2.07 | 1.8 | 3.0 | 46.5 | 309.5 | 238.5 | 343.4 | 262.9 | 5932 | 3188 |
| 1*180 | 3*45*2.30 | 2.0 | 3.0 | 50.5 | 353.0 | 272.0 | 382.7 | 295.7 | 7110 | 3725 |
| 3*240 | 3*45*2.62 | 2.2 | 3.4 | 56.2 | 415.5 | 323.3 | 446.3 | 343.4 | 8965 | 4573 |
| 3*4+1*2.5 | 3*1*2.25+1*1*1.75 | 0.8 | 1.6 | 16.8 | 31.8 | 24.4 | 39.2 | 30.7 | 492 | 403 |
| 3*6+1*4 | 3*1*2.76+1*1*2.25 | 1.0 | 1.8 | 19.3 | 41.3 | 31.8 | 50.9 | 39.2 | 644 | 515 |
| 3*10+1*6 | 3*7*1.35+1*1*2.76 | 1.0 | 1.8 | 23.0 | 55.1 | 42.4 | 67.8 | 53.0 | 1027 | 807 |
| 3*16+1*6 | 3*7*1.70+1*1*2.76 | 1.0 | 2.0 | 25.7 | 74.2 | 57.2 | 90.1 | 68.9 | 1315 | 978 |
| 3*25+1*10 | 3*7*2.14+1*7*1.35 | 1.2 | 2.2 | 29.8 | 99.6 | 77.4 | 121.9 | 90.1 | 1800 | 1272 |
| 3*35+1*10 | 3*7*2.52+1*7*1.35 | 1.2 | 2.2 | 32.0 | 126.1 | 97.5 | 151.6 | 116.6 | 2174 | 1461 |
| 3*50+1*16 | 3*10*1.9+1*7.1.70 | 1.4 | 2.6 | 34.7 | 157.9 | 121.9 | 185.5 | 143.1 | 2763 | 1748 |
Thermal stress - 热应力 (0) 投诉
P:2007-12-07 21:22:09
| 3*70+1*25 | 3*10*2.25+1*7*2.14 | 1.4 | 2.6 | 38.0 | 195.0 | 149.5 | 233.7 | 171.7 | 3498 | 2062 |
| 3*95+1*35 | 3*24*2025+1*7*2.52 | 1.6 | 2.6 | 43.0 | 239.6 | 184.4 | 269.2 | 207.8 | 4564 | 2607 |
| 3*120+1*35 | 3*24*2.55+1*7*2.52 | 1.6 | 3.0 | 16.0 | 275.6 | 213.1 | 3.7.4 | 236.4 | 5412 | 2998 |
| 3*150+1*50 | 3*45*2.07+1*19*1.78 | 1.8 | 3.0 | 50.0 | 319.1 | 244.9 | 346.7 | 267.1 | 6606 | 3548 |
| 3*182+1*50 | 3*45*2.30+1*19*1.78 | 2.0 | 3.0 | 53.9 | 365.7 | 282.0 | 391.1 | 301.0 | 7781 | 4082 |
terminal body size - 端接体尺寸 (0) 投诉
P:2007-12-07 21:22:41
<DIV align=center>VV--铜芯聚氯乙烯绝缘及护套电缆</DIV><DIV align=center> LV--铝芯聚氯乙烯绝缘及护套电缆</DIV><DIV align=center>
</DIV>
| 1 | 1*1.13 | 0.8 | 1.6 | 5.9 | 19.0 | 28.6 | 45 | |||
| 2 | 1*1.37 | 0.8 | 1.6 | 6.2 | 24.4 | 36.0 | 51 | |||
| 3 | 1*1.76 | 0.8 | 1.6 | 6.6 | 33.9 | 25.4 | 47.7 | 37.1 | 64 | 48 |
| 4 | 1*2.24 | 0.8 | 1.6 | 7.1 | 43.5 | 32.9 | 64.7 | 49.8 | 82 | 58 |
| 6 | 1*2.73 | 1.0 | 1.6 | 7.9 | 57.2 | 43.5 | 81.6 | 62.5 | 111 | 75 |
| 10 | 1*3.55 | 1.0 | 1.6 | 8.7 | 76.3 | 58.3 | 109.1 | 84.8 | 156 | 95 |
| 16 | 1*4.45 | 1.0 | 1.6 | 9.6 | 102.8 | 78.4 | 146.3 | 112.4 | 216 | 120 |
| 25 | 7*2.12 | 1.2 | 1.6 | 12.0 | 129.3 | 108.1 | 194.0 | 148.4 | 340 | 185 |
| 35 | 7*2.50 | 1.2 | 1.6 | 13.1 | 171.7 | 131.4 | 234.3 | 180.2 | 445 | 228 |
| 50 | 19*1.83 | 1.4 | 1.6 | 15.2 | 216.2 | 166.4 | 288.3 | 222.6 | 616 | 303 |
| 70 | 19*2.14 | 1.4 | 1.6 | 16.7 | 268.2 | 206.7 | 353.0 | 271.4 | 807 | 377 |
| 95 | 19*2.50 | 1.6 | 1.8 | 19.3 | 288.3 | 226.8 | 415.5 | 320.0 | 1090 | 505 |
| 120 | 19*2.80 | 1.6 | 1.8 | 20.8 | 377.4 | 292.6 | 478.1 | 368.9 | 1340 | 593 |
| 150 | 19*3.13 | 1.8 | 1.8 | 22.9 | 434.6 | 335.0 | 547.0 | 415.5 | 2060 | 730 |
| 185 | 37*2.50 | 2.0 | 2.0 | 25.5 | 492.9 | 379.5 | 606.3 | 462.1 | 2150 | 900 |
| 240 | 37*2.83 | 2.2 | 2.2 | 28.2 | 585.1 | 450.5 | 707.0 | 547.0 | 2570 | 1100 |
| 300 | 37*3.17 | 2.4 | 2.2 | 32.0 | 674.2 | 519.4 | 796.1 | 611.6 | 3216 | 1375 |
| 400 | 37*3.66 | 2.6 | 2.6 | 36.0 | 802.4 | 624.3 | 928.6 | 718.7 | 4255 | 1816 |
| 500 | 61*3.18 | 2.8 | 2.6 | 39.4 | 939.2 | 720.1 | ###### | 812.0 | 5212 | 2180 |
| 630 | 61*3.56 | 2.8 | 2.6 | 42.8 | ###### | 834.2 | ###### | 930.7 | 6412 | 3613 |
target lamp - 目标灯(架空输电线路的) (0) 投诉
P:2007-12-07 21:23:08
| 2*25 | 2*7*2.14 | 1.2 | 1.8 | 21.8 | 113.4 | 87.9 | 138.9 | 107.1 | 735 | 424 |
| 2*35 | 2*7*2.52 | 1.2 | 2.0 | 24.5 | 131.4 | 100.7 | 165.4 | 127.2 | 947 | 540 |
| 2*50 | 2*18*1.90 | 1.4 | 1.8 | 21.9 | 164.3 | 127.2 | 203.1 | 156.2 | 1177 | 568 |
| 2*70 | 2*18*2.25 | 1.4 | 2.0 | 25.0 | 207.8 | 160.1 | 249.1 | 190.8 | 1599 | 746 |
| 2*95 | 2*24*2.25 | 1.6 | 2.0 | 28.3 | 252.3 | 192.9 | 296.8 | 229.0 | 2122 | 962 |
| 2*120 | 2*24*2.55 | 1.6 | 2.2 | 31.0 | 289.4 | 223.7 | 339.2 | 261.8 | 2630 | 1165 |
| 2*150 | 2*45*2.07 | 1.8 | 2.2 | 34.0 | 333.9 | 256.5 | 386.9 | 296.8 | 3249 | 1420 |
| 3*25 | 3*7*2.14 | 1.2 | 1.8 | 23.2 | 98.6 | 76.3 | 121.9 | 92.2 | 1014 | 547 |
| 3*35 | 3*7*2.25 | 1.2 | 2.0 | 26.0 | 119.8 | 92.2 | 149.5 | 114.5 | 1554 | 902 |
| 3*50 | 3*18*1.90 | 1.4 | 2.0 | 25.8 | 148.4 | 114.5 | 181.3 | 139.9 | 1741 | 828 |
| 3*70 | 3*18*2.25 | 1.4 | 2.0 | 28.8 | 185.5 | 143.1 | 222.6 | 171.7 | 2327 | 1046 |
| 3*95 | 3*24*2.25 | 1.6 | 2.2 | 33.0 | 226.8 | 174.9 | 263.9 | 203.5 | 3125 | 1385 |
| 3*120 | 3*24*2.55 | 1.6 | 2.6 | 36.5 | 261.8 | 202.5 | 300.0 | 231.1 | 3906 | 1709 |
| 3*150 | 3*45*2.07 | 1.8 | 2.6 | 40.7 | 310.6 | 238.5 | 345.6 | 265.0 | 4836 | 2092 |
| 3*185 | 3*45*2.30 | 2.0 | 2.6 | 44.7 | 351.9 | 272.4 | 389.0 | 300.0 | 5908 | 2523 |
| 3*240 | 3*45*2.62 | 2.2 | 3.0 | 50.4 | 419.8 | 324.4 | 449.4 | 346.6 | 7629 | 3234 |
gasoline station wire - 加油站用电线 (0) 投诉
P:2007-12-07 21:23:32
| 3*4+1*2.5 | 3*1*2.25+1*1*1.78 | 0.8 | 1.6 | 12.6 | 30.7 | 23.3 | 40.3 | 30.7 | 252 | 163 |
| 3*6+1*4.0 | 3*1*2.76+1*1*2.25 | 1.0 | 1.6 | 14.7 | 40.3 | 30.7 | 50.9 | 39.2 | 351 | 222 |
| 3*10+1*6.0 | 3*7*1.35+1*1*2.76 | 1.0 | 1.6 | 17.6 | 54.1 | 42.4 | 68.9 | 53.0 | 534 | 314 |
| 3*16+1*6.0 | 3*7*1.70+1*1*2.76 | 1.0 | 1.8 | 20.3 | 72.1 | 56.2 | 89.0 | 68.9 | 759 | 422 |
| 3*25+1*10 | 3*7*2.14+1*7*1.35 | 1.2 | 2.0 | 24.4 | 97.5 | 75.3 | 117.7 | 91.2 | 1146 | 617 |
| 3*35+1*10 | 3*7*2.50+1*7*1.35 | 1.2 | 2.0 | 26.5 | 121.9 | 94.3 | 147.3 | 113.4 | 1464 | 751 |
| 3*50+1*16 | 3*18*1.90+1*7*1.70 | 1.4 | 2.0 | 28.5 | 152.6 | 117.7 | 183.4 | 141.0 | 1946 | 931 |
| 3*70+1*25 | 3*18*2.25+1*7*2.14 | 1.4 | 2.2 | 32.2 | 188.7 | 144.2 | 220.5 | 169.6 | 2661 | 1225 |
| 3*95+1*35 | 3*24*2.25+1*7*2.52 | 1.6 | 2.6 | 38.0 | 231.0 | 178.1 | 263.9 | 202.5 | 3613 | 1656 |
| 3*120+1*35 | 3*24*2.55+1*7*2.52 | 1.6 | 2.6 | 40.2 | 267.1 | 206.7 | 302.1 | 233.2 | 4331 | 1917 |
| 3*150+1*50 | 3*54*2.07+1*19*1.78 | 1.8 | 2.6 | 44.2 | 314.8 | 241.7 | 348.7 | 268.2 | 5418 | 2360 |
| 3*185+1*50 | 3*45*2.30+1*19*1.78 | 2.0 | 3.0 | 48.9 | 361.5 | 278.8 | 392.2 | 303.2 | 6571 | 2872 |
Singlemode optical fiber - 单模光纤 (0) 投诉
P:2007-12-07 21:24:08
<DIV align=center>BV型铜芯聚氯乙烯绝缘电线</DIV><DIV align=center>
</DIV>
| 标称面积m㎡ | 线芯结构on/mm | 绝缘厚度mm | 最大外径mm | 正25℃最大直流电阻 Ω/km | 正75℃时最小直流电阻 MΩ/km | 正25℃空气敷设载流量 A | 成品近似 重量 kg/km |
| 0.5 | 1*0.8 | 0.6 | 2.4 | 36.0 | 0.015 | 13.0 | 8.3 |
| 0.75 | 1*0.97 | 0.6 | 2.6 | 24.5 | 0.012 | 17.0 | 10.9 |
| 0.75 | 7*0.37 | 0.6 | 2.8 | 24.5 | 0.014 | 17.0 | 11.7 |
| 1.0 | 1*1.13 | 0.6 | 2.8 | 18.1 | 0.011 | 20.0 | 13.6 |
| 1.0 | 7*0.43 | 0.6 | 3.0 | 18.1 | 0.013 | 20.0 | 14.7 |
| 1.5 | 1*1.38 | 0.7 | 3.3 | 12.1 | 0.011 | 25.0 | 19.9 |
| 1.5 | 7*0.52 | 0.7 | 3.5 | 12.1 | 0.010 | 25.0 | 21.0 |
| 2.5 | 1*1.78 | 0.8 | 3.9 | 7.41 | 0.010 | 34.0 | 31.4 |
| 2.5 | 7*0.68 | 0.8 | 4.2 | 7.41 | 0.009 | 34.0 | 33.1 |
| 4.0 | 1*2.25 | 0.8 | 4.4 | 4.16 | ###### | 44.5 | 46.3 |
| 4.0 | 7*0.85 | 0.8 | 4.8 | 4.16 | ###### | 44.5 | 49.0 |
| 6.0 | 1.2.76 | 0.8 | 4.9 | 3.08 | ###### | 58.0 | 66.0 |
| 6.0 | 7*1.04 | 0.8 | 5.4 | 3.08 | ###### | 58.0 | 69.4 |
| 10.0 | 7*1.35 | 1.0 | 7.0 | 1.83 | ###### | 79.5 | 116.0 |
| 16.0 | 7*1.70 | 1.0 | 8.0 | 1.15 | ###### | 111.0 | 175.0 |
| 25 | 7*2.14 | 1.2 | 10.0 | 0.727 | ###### | 146.0 | 275.0 |
| 35 | 7*2.52 | 1.2 | 11.5 | 0.524 | ###### | 180.0 | 372.0 |
| 50 | 19*1.78 | 1.4 | 13.0 | 0.359 | ###### | 225.0 | 496.0 |
| 70 | 19*2.14 | 1.4 | 15.0 | 0.260 | ###### | 280.0 | 701.0 |
| 95 | 19*2.52 | 1.5 | 17.5 | 0.193 | ###### | 344.0 | 969.0 |
| 120 | 37*2.03 | 1.6 | 19.0 | 0.135 | ###### | 397.5 | ###### |
| 150 | 37*2.25 | 1.8 | 21.0 | 0.124 | ###### | 455.5 | ###### |
| 185 | 37*2.52 | 2.0 | 23.5 | 0.0991 | ###### | 519.0 | ###### |
| 240 | 61*2.25 | 2.2 | 26.0 | 0.0754 | ###### | ###### | |
| 300 | 61*2.52 | 2.4 | 29.5 | 0.0601 | ###### | ###### | |
| 400 | 61*2.85 | 2.6 | 33.0 | 0.0470 | ###### | ###### |
fungus resistance - 抗霉强度 (0) 投诉
P:2007-12-07 21:24:38
| <DIV align=center>BLV型铝芯聚氯乙烯绝缘电线</DIV> | |||||||
| 2.5 | 1*1.78 | 0.8 | 3.9 | 11.8 | 0.0 | 26.5 | 16.0 |
| 4.0 | 1*1.25 | 0.8 | 4.4 | 7.39 | 0.0085 | 34.0 | 21.7 |
| 6.0 | 1*2.76 | 0.8 | 4.9 | 4.91 | 0.0070 | 44.5 | 29.0 |
| 10.0 | 7*1.35 | 1.0 | 7.0 | 3.08 | 0.0065 | 62.5 | 53.1 |
| 16.0 | 7*1.70 | 1.0 | 8.0 | 1.91 | 0.0050 | 85.0 | 75.6 |
| 25.0 | 7*2.14 | 1.2 | 10.0 | 1.20 | 0.0050 | 111.0 | 117.0 |
| 35.0 | 7*2.52 | 1.2 | 11.5 | 0.868 | 0.0040 | 138.0 | 153.0 |
| 50.0 | 19*1.78 | 1.4 | 13.0 | 0.641 | 0.0045 | 175.0 | 202.0 |
| 70.0 | 19*2.14 | 1.4 | 15.0 | 0.443 | 0.0035 | 217.0 | 274.0 |
| 95.0 | 19*2.52 | 1.6 | 17.0 | 0.320 | 0.0035 | 265.0 | 377.0 |
| 120.0 | 37*2.03 | 1.6 | 19.0 | 0.253 | 0.0032 | 302.0 | 453.0 |
| 150.0 | 37*2.25 | 1.8 | 21.0 | 0.206 | 0.0032 | 344.5 | 560.0 |
| 185.0 | 37*2.52 | 2.0 | 23.5 | 0.164 | 0.0032 | 403.0 | 701.0 |
| 240.0 | 61*2.25 | 2.2 | 26.0 | 0.125 | 0.0032 | 905.0 | |
| 300.0 | 61*2.52 | 2.4 | 29.5 | 0.100 | 0.0030 | 1127.0 | |
| 400.0 | 61*2.85 | 2.6 | 33.0 | 0.0778 | 0.0028 | 1425.0 | |
PEF-LAP cable - 泡沫聚乙烯绝缘铝-聚乙烯粘接护套电缆 (0) 投诉
P:2007-12-07 21:25:09
| <DIV align=center>BVR型铜芯聚氯乙烯绝缘软电线(电缆)</DIV> | |||||||
| 标称面积m㎡ | 线芯结构on/mm | 绝缘厚度mm | 最大外径mm | 正20℃最大直流电阻 Ω/km | 正70℃时最小直流电阻 MΩ/km | 正25℃空气敷设载流量 A | 成品近似 重量 kg/km |
| 2.5 | 19*0.41 | 0.8 | 4.2 | 7.41 | 0.11 | 34.0 | 33.0 |
| 4.0 | 19*0.52 | 0.8 | 4.8 | 4.61 | 0.009 | 44.5 | 49.0 |
| 6.0 | 19*0.64 | 0.8 | 5.6 | 3.08 | 0.0084 | 58.0 | 71.0 |
| 10.0 | 49*0.52 | 1.0 | 7.6 | 1.83 | 0.0072 | 79.2 | 125.5 |
| 16.0 | 49*0.64 | 1.0 | 8.8 | 1.15 | 0.0062 | 111.0 | 181.0 |
| 25.0 | 98*0.58 | 1.2 | 11.0 | 0.073 | 0.0058 | 146.0 | 302.0 |
| 35.0 | 133*0.58 | 1.2 | 12.5 | 0.524 | 0.0052 | 180.0 | 395.0 |
| 50.0 | 133*0.68 | 1.4 | 14.5 | 0.378 | 0.0037 | 225.0 | 544.0 |
| 70.0 | 189*0.68 | 1.4 | 16.0 | 0.268 | 0.0045 | 280.0 | 728.0 |
filled optical cable - 填充式光缆 (0) 投诉
29
