首页 > 国外线缆
[问题求助] 寻找UL21098认证厂家
P:2007-12-05 21:24:17
各位大虾:能否提供国内有UL21098认证厂家名单。
另外与UL21098相近的UL标准能否提供,谢谢了。
length accumulator - 长度储线器 (0) 投诉
P:2007-12-06 11:23:58
没有发现国内有做21098的厂家
high speed vertical twister - 立式高速绞线机 (0) 投诉
P:2007-12-06 20:21:21
与UL21098相近的UL标准是多少,各位能否帮助一下哟,谢谢!
drum-lifting jack - 电缆盘升降用千斤顶 (0) 投诉
P:2007-12-07 10:53:32
生产厂家就不知道有哪些,能帮到你的只是给你提供UL21098的标准了.
aging characteristic - 老化特性 (0) 投诉
P:2007-12-07 21:03:43
谢谢!UL21098和UL2587的区别在什么地方,能否指点一下。
description - 描写, 记述, 形容, 种类, 描述,品名 (0) 投诉
P:2007-12-10 10:07:59
UL21098要求用耐油料,而UL2587则不用耐油料.
steel buried type optical indoor cable - 钢丝埋入式户内光缆(四根支承钢丝埋设在PVC护套内) (0) 投诉
P:2007-12-10 10:27:06
ASSOCIATED WIRE PRODUCTS INC
Appliance Wiring Material - Component
<SCRIPT language=JAVASCRIPT> BldLink("AVLV2.E306556", "/cgi-bin/XYV/template/LISEXT/1FRAME/showpage.html" + "?name=AVLV2.E306556&ccnshorttitle=Appliance Wiring Material - Component" + "&objid=1078273830&cfgid=1073741824&version=versionless" + "&parent_id=1073744548&sequence=1") </SCRIPT>AVLV2.E306556
JAMES MONROE WIRE & CABLE CORP
<SCRIPT language=JAVASCRIPT> BldLink("AVLV2.E66440", "/cgi-bin/XYV/template/LISEXT/1FRAME/showpage.html" + "?name=AVLV2.E66440&ccnshorttitle=Appliance Wiring Material - Component" + "&objid=1073745487&cfgid=1073741824&version=versionless" + "&parent_id=1073744548&sequence=1") </SCRIPT>AVLV2.E66440
U I LAPP GMBH
<SCRIPT language=JAVASCRIPT> BldLink("AVLV2.E63634", "/cgi-bin/XYV/template/LISEXT/1FRAME/showpage.html" + "?name=AVLV2.E63634&ccnshorttitle=Appliance Wiring Material - Component" + "&objid=1073745628&cfgid=1073741824&version=versionless" + "&parent_id=1073744548&sequence=1") </SCRIPT>AVLV2.E63634
XBK-KABEL XAVER BECHTOLD GMBH
<SCRIPT language=JAVASCRIPT> BldLink("AVLV2.E137972", "/cgi-bin/XYV/template/LISEXT/1FRAME/showpage.html" + "?name=AVLV2.E137972&ccnshorttitle=Appliance Wiring Material - Component" + "&objid=1073746504&cfgid=1073741824&version=versionless" + "&parent_id=1073744548&sequence=1") </SCRIPT>AVLV2.E137972
21098全球就这四家公司有认证,没有中国企业.
trailable seismic streamer cable - 海洋地震探测用拖曳电缆 (0) 投诉
