[问题求助] 寻找high flex cable国内电缆制造商
P:2007-12-05 17:15:01
求购以下电缆:
1)4022 363 40351 Li12YDD11Y 3x0.25mm + 2x0.04 mm UL
High flexible PUR Cable 3 x 0.25mm2 + 2 x 0.05mm2
Wire colours: 0.25mm2: black, white, red; 0.05mm2: yellow, green
Outer sheath: TPU Black
Screening (2 –folded D-shield CU-tin-plated)
UL certified 90°C 90V
Heading text: Tecnotion << OLE Object: Afbeelding (Metabestand) >> AWM STYLE 20671 90°C 90V E63216
Outerdiameter £ 5mm
Wear-resistant
Bending cycli > 15 million
Bending radius 40mm
Suitable for cable chains
reinforced sheath - 增强型护套 (0) 投诉
P:2007-12-06 14:04:05
能不能用中文,.英文我看不懂
optical cable composite connector - 组合式光缆连接器 (0) 投诉
P:2007-12-07 18:24:28
好像“四川明星电缆有限公司http://www.--mxdl.cn/”做这种超细的线。
water-stop nonwoven - 堵水无纺布 (0) 投诉
P:2007-12-10 16:21:42
thanks qiaoen
cold lead-in cable - 冷端引入电缆 (0) 投诉
