首页 > 标准共享
[国外标准] IEC 60331-2:2018 Tests for electric cables under fire conditions – Circuit integrity – Part 2: Test method for fire with shock at a temperature of at least 830 °C for cables of rated voltage up to and including 0,6/1,0 kV and with an overall diameter
P:2018-12-17 16:36:20
IEC 60331-2:2018 Tests for electric cables under fire conditions – Circuit integrity – Part 2: Test method for fire with shock at a temperature of at least 830 °C for cables of rated voltage up to and including 0,6/1,0 kV and with an overall diameter.pdf
raw material - 原材料 (0) 投诉
