首页 > 标准共享
[国外标准] IEC 60331-3-2018 Tests for electric cables under fire conditions-Circuit integrity-Part 3: Test method for fire with shock at a temperature
P:2018-12-17 13:29:04
IEC 60331-3:2018 Tests for electric cables under fire conditions-Circuit integrity-Part 3: Test method for fire with shock at a temperature of at least 830°C for cables of rated voltage up to and including 0.6/1.0 kVtested in a metal enclosure.pdf
t.b.w.p. - triple-braided weather-proof三股编包风雨线 (0) 投诉
