首页 > 标准共享
[国外标准] IEC 60331-1-2018 Tests for electric cables under fire conditions - Circuit integrity - Part 1: Test method for fire with shock at a temperature of at least 830 °C for cables of rated voltage up to and including 0,6/1,0 kV and with an overall diameter
P:2018-12-15 09:21:42
songfeiX 奖励 10 金币,5 声望,于 2018-12-15 09:36:48 原因:奖罚
elastic deformation - 弹性变形 (0) 投诉
P:2018-12-15 09:45:11
标准不错
CCC - communication control center通信控制中心 (0) 投诉
P:2018-12-16 15:21:15
怎么没人下载呢
land-bassed fibreoptic cable - 陆上光缆 (0) 投诉
P:2018-12-17 11:07:41
你把标题写错了,应该是IEC 60331
service entrance conductor - 用户引入线 (0) 投诉
P:2019-07-23 15:17:43
文不对题,
rod in tube method - 管棒法 (0) 投诉
P:2019-07-29 17:03:07
标题写错了
binding die - 绑扎模(SZ绞制机的) (0) 投诉
P:2019-08-12 14:47:50
没金币啊  大哥
OCD - out of cell delineation信元失步 (0) 投诉
