首页 > 辐照 紫外 蒸汽交联
[电子辐照] 辐照交联F40J(XETFE)
P:2007-11-16 17:38:58
IPI - initial product inspection原始产品检验 (0) 投诉
P:2007-11-16 19:05:39
為什麼這麼貴,老兄,可不可傳給我一下Denny_bj@163.com,我沒有錢呢
n-hole lay-plate - n-孔分线板 (0) 投诉
P:2007-11-16 21:50:35
辐照交联etfe应该耐温200度
water repellent wire - 防水型电线 (0) 投诉
P:2007-11-25 15:05:15
交联F40耐温可到180度。一般用150度
OFDR - optical frequency domain reflectometer[reflector]光频域反射计[器] (0) 投诉
P:2007-11-25 15:13:34
是我上传时没有选择好。对住各位
XETFE
field wire - 野战被复线,军用电线 (0) 投诉
P:2007-12-06 23:05:59
能给我发一份吗?谢谢xingworsn@163.com
tetrode - 四极管 (0) 投诉
P:2007-12-28 07:59:06
请发一份到我邮箱好吗?谢谢 sandy8110@163.com
CRTC - Canadian Radio-Television Commission加拿大无线电电视委员会 (0) 投诉
P:2007-12-30 08:42:06
有没有相关的论文阿?
special test - 特殊试验 (0) 投诉
P:2008-05-20 14:14:57
gf119@sina.com
能给我发一份么?非常感谢
sector shaped stranded conductor - 扇形绞合导体 (0) 投诉
P:2009-05-23 10:19:35
电线电缆
英国国防部标准与大家分享
def stan 61-12等这些都是2000年以后的标准,最新的是2008年标准
其中有XTFE绝缘电线
DEF STAN 61-12 PART 4 Defence Standard 61-12 part4 issue 4.pdf
DEF STAN 61-12 PART 5 Defence Standard 61-12 part5 issue 5.pdf
DEF STAN 61-12 PART 6 Defence Standard 61-12 part6 issue 6.pdf
DEF STAN 61-12 PART 9 Defence Standard 61-12 part9 issue 5.pdf
DEF STAN 61-12 PART 10 Defence Standard 61-12 part10 issue 2.pdf
DEF STAN 61-12 PART 12 Defence Standard 61-12 part12 issue 2.pdf
DEF STAN 61-12 PART 16 Defence Standard 61-12 part16 issue 1.pdf
DEF STAN 61-12 PART 16 Defence Standard 61-12 part16 section 2 issue 1.pdf
DEF STAN 61-12 PART 16 Defence Standard 61-12 part16 section 3 issue 1.pdf
DEF STAN 61-12 PART 17 Defence Standard 61-12 part17 issue 1.pdf
DEF STAN 61-12 PART 18 Defence Standard 61-12 part18 issue 5.pdf
DEF STAN 61-12 PART 20 Defence Standard 61-12 part20 issue 1.pdf
DEF STAN 61-12 PART 25 Defence Standard 61-12 part25 issue 4.pdf
DEF STAN 61-12 PART 26 Defence Standard 61-12 part26 issue 3.pdf
DEF STAN 61-12 PART 27 Defence Standard 61-12 part27issue 3.pdf
DEF STAN 61-12 PART 30 Defence Standard 61-12 part30 issue 1.pdf
DEF STAN 61-12 PART 31 Defence Standard 61-12 part31 issue 2.pdf
DEF STAN 61-12 PART 33 Defence Standard 61-12 part33 issue 4 supplement 008.pdf
DEF STAN 61-12 PART 33 Defence Standard 61-12 part33 issue 5.pdf
DEF STAN 61-12 PART 33 Defence Standard 61-12 part33 issue 5 135 200 260.pdf
DEF STAN 61-12 PART 33 Defence Standard 61-12 part33 issue 5 supplement001.pdf
DEF STAN 61-12 PART 0 Defence Standard 61-12 part 0.pdf
Multicore Def Stan 6 12 pt5 Cables.pdf
FSD 0200E:1999 STANDARDS FOR ELECTRONIC COMPONENTS AND DESIGN WORK.pdf
管理员 奖励 80 金币,.2 声望,于 2009-9-13 10:45:59 原因:奖励
irradiation curing - 辐照交联 (0) 投诉
P:2009-05-31 17:33:00
交联乙烯—四氟乙烯共聚物(XETFE),这种材料也需要辐照吗,一般我们接触的辐照材料以XLPE、XLPVC为主。
optics - 光学 (0) 投诉
P:2009-09-18 09:56:06
XLETFE或XETFE是氟塑料产品中新成员,是由ETFE改性,耐温性大幅提高。
rate of adhesion - 粘附率 (0) 投诉
P:2009-11-07 13:10:22
长期工作温度可以达到200度的
applicator roll - 供漆辊 (0) 投诉
P:2010-02-10 15:20:44
交联ETFE主要还是杜邦一类公司供应。
outer curvature radius - 外部曲率半径 (0) 投诉
P:2010-03-01 12:29:58
可以发一份给我吗,我的邮箱gys_1982@163.com
非常感谢
double block drawing machine - 双层鼓轮拉线机 (0) 投诉
36
