首页 > 特种电缆
[硅胶电缆] 关于硅橡胶高压线UL3239的技术标准!
P:2006-10-05 14:42:29
既然是UL的标准,我想应该会有一个统一的标准吧
但事实却是,我在网上查了不少,竟然都不统一,真的让我感到意外不小
谁有这样的标准,给予分享下!谢谢了!
embedded control channel - 嵌入控制通路 (0) 投诉
P:2006-10-06 09:17:44
有人知道么?
分享一下啊!我还是没能找到!
lime box - 白垩粉盒 (0) 投诉
P:2006-11-13 19:05:32
UNDERWRITERS LABORATORIES INC. APPLIANCE WIRING MATERIAL
Subject 758 Section 3 Page 3239 Issued: 1969-10-13
Revised: 2003-08-21
Style 3239
High-Voltage Lead Wire.
Rating
Maximum 200°C and 50 KVDC. See Facing Page for ratings.
Conductor
Nos. 24-10 AWG copper or nickel and Nos. 12-10 AWG aluminium or Nos. 27-20 AWG Resistance Wire; solid or stranded. Or Nos. 24-10 AWG solid or stranded coated high strength copper - min 90% conductivity, for 200°C rating uncoated or tinned strands of copper shall be 0.015 inch or larger in diameter. Aluminium conductors shall be permitted for a 90°C maximum operating temperature. Copper conductors may be tinned, silver or nickel plated, heat bonded or overcoated.
Insulation
Thermoplastic and/or Thermosetting. See Facing Page for details.
Shield
Optional, see Facing Page for details.
Covering
Jacket
Standard
Appliance Wiring Material UL 758.
Instructions
to UL
Representative
Detailed Examination, see Facing Page.
Physical Properties of Insulation, Covering and/or Jacket, unaged.
High Voltage DC Dielectric Withstand Method I, unaged,
Humidity conditioning 6 hours.
VW-1 Flame Test.
UL
Counter-Check
Program
(4) Detailed Examination, see Facing Page.
(4) Physical Properties of Insulation, Covering
and/or Jacket, unaged and after aging.
(4) Heat Shock.
(4) Shrinkage.
(4) Deformation
(12) VW-1 Flame Test.
(1) High-Voltage Cut-Through Test.
(1) High Voltage DC Dielectric Withstand
Methods I and II, unaged and after aging.
(4) Ozone Resistance Test.
(Continued on Page 3239A)
Subject 758 Section 3 Page 3239A Issued: 1969-10-13
Revised: 2003-08-21
Marking
General.
If the outer surface of the wire is PVC,XLPVC, PVDF, PE, XLPE, XLPO, or glass or cotton braid, the wire shall be surface printed. Surface printing on other materials is optional unless other-wise noted on the facing page.
1. Recognized's Company’s name or E number.
2. Plant identification, if made in more than
one location.
3. DC voltage rating.
4. Temperature rating, if above 60°C.
5. Style No. 3239.
6. The Recognized Component Mark followed by the
letters AWM or the words, Appliance Wiring
Material.
7. (Optional) VW-1.
Use
Internal wiring of TV receivers or where the acceptability has been determined by Underwriters Laboratories.
cross-linkable silane graftpolymer - 可交联硅烷接枝聚合物 (0) 投诉
P:2006-11-13 19:06:47
不知道對樓主有幫助嗎
support member - 支承构件(架空电[光]缆的) (0) 投诉
P:2006-12-25 00:14:58
外语水平低,哪位劳驾帮帮忙
tracer color - 标志色,线芯标志色,标记颜色 (0) 投诉
P:2007-03-18 00:24:27
硅胶高压线没有明确的标准,主要是看你认证的证书要求是怎么样的UL就按照你证书的要求检验的
metal spraying equipment - 金属喷镀设备 (0) 投诉
P:2007-03-18 16:40:34
谁帮助译成中文好吗
International Wire association - 国际线材协会 (0) 投诉
P:2009-04-01 16:38:30
那位劳驾翻译一下。谢谢
of resistance to cold - 耐寒试验 (0) 投诉
P:2009-09-02 14:36:01
那位劳驾翻译一下。谢谢
high capacity wire drawing machine - 高效率拉线机 (0) 投诉
P:2010-01-28 21:09:13
的春仅此
conductor glaze formation - 导线覆冰,导线雨淞 (0) 投诉
P:2010-11-18 19:35:06
做电缆得外语很好啊
off-center - 偏心,中心偏移;不对称 (1) 投诉
P:2011-07-27 14:24:45
都告诉你了,应该靠自己了
Z-profile wire - Z形剖面钢丝 (0) 投诉
