首页 > 航空 铁路 船港
[铁路机车] 125℃及以下标准壁厚绝缘总屏蔽机车车辆电缆
P:2018-09-19 09:09:20
适用于机车内部、隧道、地铁站等,要求电缆无卤、低烟、阻燃防火安全性场合,用于设备之间信号和控制回路的连接。
使用特性
温度范围:-40℃~+100℃
-40℃~+125℃;
额定电压:250V、750V;
试验电压:
250V1500V/5min
750V3500V/5min;
安全性:电缆低烟、无卤、阻燃;
电缆耐油Ⅲ级;
最小弯曲半径:4D,有屏蔽为6D(D:电缆外径);
参照标准
1.机车车辆电缆:TB/T1484.1-2010
2.火灾安全性标准:BS6853/DIN5510
3.电缆的导体:GB/T3956-2008
4.镀锡圆铜线:GB/T4910-2009
技术参数
电缆芯数×截面
(mm2)
导体结构
根/直径
绝缘外径(mm)电缆外径(mm)导体电阻
Ω/km
250V750V250V750V
2×0.516/0.21.7/6.85/40.1
2×0.7524/0.21.952.757.38.926.7
2×132/0.22.12.97.69.220
2×1.530/0.252.63.28.29.813.7
2×2.550/0.2533.69.110.78.21
2×456/0.33.64.210.211.85.09
3×0.516/0.21.7/7.1/40.1
3×0.7524/0.21.952.757.69.326.7
3×132/0.22.12.97.99.720
3×1.530/0.252.63.28.510.313.7
3×2.550/0.2533.69.511.28.21
3×456/0.33.64.210.712.45.09
4×0.516/0.21.7/7.6/40.1
4×0.7524/0.21.952.758.11026.7
4×132/0.22.12.98.510.420
4×1.530/0.252.63.29.211.113.7
4×2.550/0.2533.610.312.28.21
4×456/0.33.64.211.513.55.09
5×0.516/0.21.7/8/40.1
5×0.7524/0.21.952.758.610.826.7
5×132/0.22.12.99.111.320
5×1.530/0.252.63.29.81213.7
5×2.550/0.2533.611.113.28.21
5×456/0.33.64.212.614.75.09
6×0.516/0.21.7/8.6/40.1
6×0.7524/0.21.952.759.212.626.7
6×132/0.22.12.99.712.120
6×1.530/0.252.63.210.512.913.7
6×2.550/0.2533.611.914.38.21
6×456/0.33.64.213.616.25.09
7×0.516/0.21.7/8.6/40.1
7×0.7524/0.21.952.759.212.626.7
7×132/0.22.12.99.712.120
7×1.530/0.252.63.210.512.913.7
7×2.550/0.2533.611.914.38.21
7×456/0.33.64.213.616.25.09
8×0.516/0.21.7/9.1/40.1
8×0.7524/0.21.952.759.812.426.7
8×132/0.22.12.910.41320
8×1.530/0.252.63.211.313.913.7
8×2.550/0.2533.612.815.68.21
8×456/0.33.64.214.617.45.09
9×0.516/0.21.7/9.8/40.1
9×0.7524/0.21.952.7510.613.526.7
9×132/0.22.12.911.214.220
9×1.530/0.252.63.212.215.413.7
9×2.550/0.2533.613.917.18.21
9×456/0.33.64.21619.15.09
10×0.516/0.21.7/10.3/40.1
10×0.7524/0.21.952.7511.114.326.7
10×132/0.22.12.911.815.220
10×1.530/0.252.63.212.916.313.7
10×2.550/0.2533.614.818.28.21
10×456/0.33.64.217.220.45.09
11×0.516/0.21.7/10.6/40.1
11×0.7524/0.21.952.7511.414.726.7
11×132/0.22.12.912.215.720
11×1.530/0.252.63.213.316.813.7
11×2.550/0.2533.615.418.78.21
11×456/0.33.64.217.7215.09
12×0.516/0.21.7/10.6/40.1
12×0.7524/0.21.952.7511.414.726.7
12×132/0.22.12.912.215.720
12×1.530/0.252.63.213.316.813.7
12×2.550/0.2533.615.418.78.21
12×456/0.33.64.217.7215.09
13×0.516/0.21.7/11/40.1
13×0.7524/0.21.952.7511.915.726.7
13×132/0.22.12.912.716.420
13×1.530/0.252.63.213.917.613.7
13×2.550/0.2533.616.119.78.21
13×456/0.33.64.218.622.35.09
14×0.516/0.21.7/11/40.1
14×0.7524/0.21.952.7511.915.726.7
14×132/0.22.12.912.716.420
14×1.530/0.252.63.213.917.613.7
14×2.550/0.2533.616.119.78.21
14×456/0.33.64.218.622.35.09
15×0.516/0.21.7/11.5/40.1
15×0.7524/0.21.952.7512.516.426.7
15×132/0.22.12.913.317.320
15×1.530/0.252.63.214.618.613.7
15×2.550/0.2533.61720.78.21
15×456/0.33.64.219.523.55.09
16×0.516/0.21.7/11.5/40.1
16×0.7524/0.21.952.7512.516.426.7
16×132/0.22.12.913.317.320
16×1.530/0.252.63.214.618.613.7
16×2.550/0.2533.61720.78.21
16×456/0.33.64.219.523.55.09
17×0.516/0.21.7/12/40.1
17×0.7524/0.21.952.751317.326.7
17×132/0.22.12.913.918.220
17×1.530/0.252.63.215.519.513.7
17×2.550/0.2533.617.821.88.21
17×456/0.33.64.220.625.25.09
18×0.516/0.21.7/12/40.1
18×0.7524/0.21.952.7513.117.326.7
18×132/0.22.12.913.918.220
18×1.530/0.252.63.215.519.513.7
18×2.550/0.2533.617.821.88.21
18×456/0.33.64.220.625.25.09
19×0.516/0.21.7/12/40.1
19×0.7524/0.21.952.7513.117.326.7
19×132/0.22.12.913.918.220
19×1.530/0.252.63.215.519.513.7
19×2.550/0.2533.617.821.88.21
19×456/0.33.64.220.625.25.09
decryption - 解密 (0) 投诉
P:2018-09-19 09:45:57
TB/T 1484.1现在已经2017版了    相较于2010版变化比较多,  多了小尺寸规格和电压等级变化   从250V和750V  改为300V和600V了
管理员 奖励 5 金币,3 声望,于 2018-09-20 08:09:22 原因:奖罚
antiscorching agent - 防焦剂 (0) 投诉
P:2018-09-21 21:11:42
您是技术还是销售?
Master franchise - 特约总经销 (0) 投诉
