[材料介绍] 无卤阻燃透明TPU料
P:2007-11-13 10:26:43
我司开发一只无卤阻燃透明TPU料:
性能如下:
A. Description:
Chemstoran-FRS80 is a flame-retarded halogen-free, heavy Metal free , thermal plastic polyester-polyurethane for extrusion application with exceptional properties.
1. Transparency |
2. Flexibility/Elasticity |
3. Folding Test over 100,000 times |
4. UL94 VO |
B Physical Properties
1. Appearance | :Transparent Colorless ~Slightly yellow pallet |
2. Shore A hardness | : |
3. Specific Gravity | : 1.2 |
4. Tensile Strength (kg/cm2) | : 180↑ |
5. 100% Modulus (kg/cm2 ) 300% Modulus (kg/cm2) | : 35↑ : 60↑ |
6. Elongation (%) 7. M I (g/10min, | : 300 % : 20-40 |
8. Melting Point(℃) | : 115~ |
C. Application
Jacket for cables
Cables brushings profiles, hoses spiral hoses, Wire &Cable
D. Drying Conditions
Drying Temperature /time:
E. Package
F. Processing Temperature
如有疑问:欢迎致电:13138814366 叶高锋
[copartner 在 2007-12-19 10:46:08 编辑过]
shock test - 冲击试验 (0) 投诉
P:2007-11-13 10:27:26
Certificate of Analysis
Date:
Product Name | CHEMSTORAN-FRS80 | |
B | ||
Test Item | Test Method | Test Result |
1. HARDNESS (SHORE A/D) | ||
2. 100% MODULUS (kg/cm2) | JTS K7311 | 80 |
3. 300% MODULUS (kg/cm2) | JTS K7311 | 175 |
4. TENSILE STRENGTH (kg/cm2) | JTS K7311 | 212 |
5. ELONGATION (%) | JTS K7311 | 368 |
6. MELT VISCOSITY (POISE) | FLOW TESTER | 5521 |
老化測試報告
品名 | 批號 | 測試條件 | 黏度 | 硬度 | 100% kg/cm2 | 300% kg/cm2 | 抗張力 kg/cm2 | 伸長率% |
HR | A | 5521 | 80 | 175 | 212 | 368 | ||
HR | A | 69 | 145 | 345 | 542 | |||
保持率% | 86.25 | 82.85 | 162.73 | 147.28 |
MGT - Multi-Gigabit Transceiver的缩写,是multi-gigabit Serializer/Deserializer (SERDES)的别称。它接受并行数据,允许高带宽数据在串行线中传输。 (0) 投诉
P:2007-11-20 20:10:42
pack-former for wire - 线材捆扎装置,捆线机 (0) 投诉
