首页 > 专业英语|国际贸易
[专业词汇] 我总结的一些plc专用词汇
P:2007-11-04 13:11:12
  单词 解释 例句或者词组 音标
abbrivation 缩写 [ə,bri:vi`eifn]
absolute 绝对 absolute output 绝对最大输出 [`aebsəlu:t]
actuator 执行器
against 对比 I/O signals against PC CPU
allocate 分配 allocate the user area in buffer memory [`aeləkeit]
alter 改变 even if the output characteristic is altered by changing offset/gain
setting [`o:tə]
ambient 环境 周围 ambient operating temperature [`aembiənt]
analog 模拟 analog output [`aenəlog]
analysis 分析 the collection an and analysis of data [ə`naeləsis]
applicable 可用 the applicable CPU for the module
assign 分配 The teacher has assigned each of us a holiday task. assign I/O number
[ə`sain]
back up battey 备用电池
barcode reader/ID 条形码阅读器
base unit 主基板
baud 波特 [bo:d]
beforehand 事先
binary 二进制 12 bit binary  [`bainəri]
buffer memory 缓冲存储器
bus 总线
case 外壳 do not remove the module's print board from the case
characteristic 特征 I/O characterristic [`kaerəktə`ristik]
check 校验 the data link status canbe checked
child-station 子站
common terminal 公共端
compatible 兼容 compatible with the MODBUS protocol
compound 混合 compound system communication [`compaund]
condensation 结露
condition 条件 condition setting
conductive 导电 conductive metal picees
configuration 组态 system configuration
configure 组态
confirm 确认 how to confirm the operation of the module
consumption 消耗 current consumption [kən`s^mp∫n]
content  目录
control level 控制级
convenient 方便 more convenient and easy-to-use
interstitial quad - 填隙四线组,间充四线组,填隙式四线组,间充式四线组 (0) 投诉
P:2007-11-04 13:11:48
conventionaly 传统 which conventionaly has been used [kən,venfen'aeləti]
conversion 转换 Analog-Digital conversion module
converter 转换器 [cən`və:tə]
conveyor 传送 conveyor line [cən`veiə]
corrosive 腐蚀 corrosive gas [kə`rəusiv]
countermeasure 对策 countermeasure for mis-inpute
cutoff 切断
debug 调试 is recommended before debugging
dedicated 屏蔽 cc-link dedicated cable
dedicated 专用 dedicated transmission protocol
default value 缺省值
define 解释 阐明  Offset value and gain value are defined as follow. [di`fain]
design 设计 design a system
device level 现场级
diagnosis 诊断 diagnosis function [daiəg`nəusis]
digital 数字 digital inpute
DIN rail 导轨
diverse 不同的各种各样的 a diverse application requirements [dai`və:s]
download  下载
duplicate 完全一样 [`dju:plikət]
dust 灰尘
eliminate 免得 [i`limineit]
enterprise level 管理级 [`entəprais]
erase 清除
exceed 超出 The number admitted must not exceed 200 [ik`si:d]
execute 执行 date link is executed using these parameters [`eksikju:t]
expand 扩展 can be eapanded up to 255 networks
faulty  故障站
field bus  现场总线
fix 固定
flexibly 灵活的 to support a variety systerm flexibly [`fleksəbli]
flow 流量
format 格式 transmission format [`fo:maet]
frame
fuse 融丝
graph 图标 坐标图 曲线图 voltage output characterristic graph [gra:f]
guaranteed 担保 nomal operration cannot be guaranteed [,gaerə`ti:d]
handle 处理
hardware manual 硬件手册
hint 提示 programming hints
humidity 湿度 ambient operating humdlity
individual 独立的
inductance  电感 inductance load
initiate 实施 发起 can be initiate by a computer [i`nifieit]
programmer - 程序设计器,程序装置;程序编制员 (0) 投诉
P:2007-11-04 13:12:23
input  输入
input point 输入点数
install 安装
instruction 指令 the FROM instruction
insulation 隔离 form rubber provides good insulation [,insju`leifn]
interface 接口 [`intəfeis]
interlocking 互锁 can be used for sequence program interlocking
internal external 内部 外部 internal connection
interrupt 中断 excute an interrupt processing
invalid 无效 error invalid station function
magnetic 有磁性的 magnetic fields [maeg`netik]
main circuit 主回路 [`sə:kit]
malfunction 故障 cause system malfunction
mandatory 强制 [`maedətəri]
mantenance 维护 maintenance costs are reduced [`meitənəns]
manual 手册 User' Manual
mechanical 机械 michanical life机械寿命
module  模块 mount or remove the module [`modju:l]
momentary power failure 瞬时断电
monitor 监视
mount 固定  mount or remove the module
multiple 多样 mutiple remote i/o modules
negative  负
observation 观察 [obzə`veifn]
occupy 占用 occupies 1 station [`okju:pai]
occur 发生
offline 离线 offline test
offset gain 偏置增益
oil mist 油雾
optical loop 光缆回路 [`optikəl]
optimum 最佳的 optimum control [`optiməm]
output 输出
overall 总的 overall distance
overview 总揽 communication overview
parameter 参数
path 路径 transmission path
per network
perform 进行 normal data link cannot be performed
performance specifations 性能规格
peripheral 外围 When utilizing peripheral device to assign I/O number.
[pə`rifəriərəl]
phase 相 swith off all phases of the power supply [`feiz]
photocoupler
point 要点
silica glass - 石英玻璃 (0) 投诉
P:2007-11-04 13:12:51
port  口 Rs232c port
positive  正
power line 电源线
power on/off 上电断电
precaution 注意事项 precaution when configuing system
print board 印刷电路板 do not remove the module's print board from the case
procedure 过程 follow the procedure
programing interface 编程口
protocol 协议 protocol communication issues [`prəutəcol]
range 范围
rated input voltage 额定输入电压
ratio 比率 [`reifiəu]
recommend 建议 is recommended before debugging
reduce 减少 the number of steps in operation program can be reduced
refer to  参照 refer to Chapter 6
register 数据寄存器
relay 继电器 [`ri:lei]
remote I/O 远程网络IO [ri`məut]
reserved station 预留主站
resin 树脂 made of resin
resistor 电阻 resistor load阻性负载  terminating resistor [ri`zistə]
resolution 分解,解析 n Maximum resolution  最大分辨率 [,rezə`lu:fn]
restriction 限制 no restriction [ri`strikfn]
retry 从试
scan 扫描 link scan
screw 螺丝 Teminal- block screw
seamless network 无缝网络
sequence programme 顺控程序
serial communications module 串口模块
series 系列 Ans Series [`siəriəs]
servo 伺服
short 短路
signal 信号
sink 漏极 sink commen
slot 槽
soures 源极 soures commen
specifications 特性 input modules specifications
stabilized power supply 稳压电源 [`steibəlaiz]
standby master station 备用主站
start up  起动
status 状态 data link status
step drive 步进
storage 存储 storage area
store 存储
clean cable - 洁净电缆(为在火灾时易于避难和灭火 等目的而设计的一种无卤低烟阻燃型聚烯烃绝缘电缆) (0) 投诉
P:2007-11-04 13:13:04
switch off 关断 swith off all phases of the power supply
swith 开关
table 表格
transfer 传输
transistor 晶体管
transmission speed 传输速度
transmit 传送 data is transmitted in unchanged code
triac 双端三相可控硅开关
troubleshooting 故障处理
unuseble 不可以使用
upload 上传
utilize 利用 When utilizing peripheral device to assign I/O number.
[`ju:təlaiz]
verify 校验 verify the set parameter contents
voltage 电压 high voltage [`vəultidg]
watchdog 看门狗
width 范围 it will vary in the width of [widθ]
wire chips 线头 do not let foreign matter such as wire chips ret inside the module
shield standing voltage - 屏蔽层电压,屏蔽稳态电压,接地屏蔽层固定电压 (0) 投诉
P:2007-11-04 21:05:17
感谢楼主的资料!顶
AOFOSS - automatic optical fiber operations support system自动光纤工作支持系统 (0) 投诉
P:2008-03-12 10:18:11
是不错的资料,
hard braking - 急刹车 (0) 投诉
P:2008-03-14 14:52:38
初学者在此谢谢楼主!!请更多指教!
NCL - network connection link网络连接链路; (0) 投诉
P:2008-12-22 13:52:11
感谢楼主的资料!顶
portal-type take-up system - 门式收线系统 (0) 投诉
P:2008-12-23 12:52:42
感谢楼主的资料!
identification tape - 标志带 (0) 投诉
P:2009-06-17 15:35:11
谢谢分享  好东西
top-quality telephone wire - 最高质量电话线 (0) 投诉
P:2009-06-23 08:47:07
蛮不错的!
alternate stranding - 交替绞合 (0) 投诉
P:2010-08-19 15:53:15
谢谢楼主的资料 顶呀
Fahrenheit temperature - 华氏温度,F (0) 投诉
P:2011-12-28 10:41:32
哥们太有才了
purging compound - 清洗用混合物(挤塑) (0) 投诉
