首页 > 标准共享
[国外标准] MIL-24643 舰船用电线电缆详细规范(多集合)
P:2018-08-22 08:43:32
跟大家交流,美军标!
美军标,这里面太少了!
有 SAE  AS 22759 最新版的,鼓励上传分享!
MIL-DTL-24643/1B-1D:2008 DETAIL SPECIFICATION CABLES AND CORDS, ELECTRIC, LOW SMOKE, FOR SHIPBOARD USE GENERAL SPECIFICATION FOR.pdf
MIL-DTL-24643/1C-1:2009 DETAIL SPECIFICATION CABLES, ELECTRIC, LOW SMOKE HALOGEN-FREE, FOR SHIPBOARD USE GENERAL SPECIFICATION FOR.pdf
MIL-DTL-24643/5G:2009 DETAIL SPECIFICATION SHEET CABLE, ELECTRICAL, -20 °C TO +90 °C, 600 VOLTS, TYPE LSMDU.pdf
MIL-DTL-24643/7F:2009 DETAIL SPECIFICATION SHEET CABLE, ELECTRICAL, -20 °C TO +90 °C, 600 VOLTS, TYPE LSMHOF.pdf
MIL-DTL-24643/4E:2009 DETAIL SPECIFICATION SHEET CABLE, ELECTRICAL, -20 °C TO +90 °C, 600 VOLTS, TYPE LSMCOS.pdf
MIL-DTL-24643/8E:2009 DETAIL SPECIFICATION SHEET CABLE, ELECTRICAL, -20 °C TO +90 °C, 300 VOLTS, TYPE LSMMOP.pdf
MIL-DTL-24643/10D:2009 DETAIL SPECIFICATION SHEET CABLE, ELECTRICAL, -20 °C TO +90 °C, TYPE LSPBTMU.pdf
MIL-DTL-24643/11E:2009 DETAIL SPECIFICATION SHEET CABLE, ELECTRICAL, -20 °C TO +90 °C, 600 VOLTS, TYPE LSSSF.pdf
MIL-DTL-24643/9F:2009 DETAIL SPECIFICATION SHEET CABLE, ELECTRICAL, -20 °C TO +90 °C, TYPE LSMRI.pdf
MIL-DTL-24643/12F:2009 DETAIL SPECIFICATION SHEET CABLE, ELECTRICAL, -20 °C TO +90 °C, 300 VOLTS, TYPE LSTTOP.pdf
MIL-DTL-24643:13F/2009 DETAIL SPECIFICATION SHEET CABLE, ELECTRICAL, -20 °C TO +90 °C, 300 VOLTS, TYPE LSTTRS.pdf
MIL-DTL-24643/2F:2009 DETAIL SPECIFICATION SHEET CABLE, ELECTRICAL, -20 °C TO +90 °C, 300 VOLTS, TYPE LSDCOP AND LSTCOP.pdf
MIL-DTL-24643:15F/2009 DETAIL SPECIFICATION SHEET CABLE, ELECTRICAL, -20 °C TO +105 °C, 1000 VOLTS, TYPE LSDSGU.pdf
MIL-DTL-24643/17F:2009 DETAIL SPECIFICATION SHEET CABLE, ELECTRICAL, -20 °C TO +105 °C, 1000 VOLTS, TYPE LSFSGU.pdf
MIL-DTL-24643:18F/2009 DETAIL SPECIFICATION SHEET CABLE, ELECTRICAL, -20 °C TO +105 °C, 1000 VOLTS, TYPE LSMSCU.pdf
MIL-DTL-24643/14F:2009 DETAIL SPECIFICATION SHEET CABLE, ELECTRICAL, -20 °C TO +105 °C, 1000 VOLTS, TYPE LSSSGU.pdf
MIL-DTL-24643/20F:2009 DETAIL SPECIFICATION SHEET CABLE, ELECTRICAL, -20 °C TO +105 °C, 1000 VOLTS, TYPE LS7SGU.pdf
MIL-DTL-24643/21F:2009 DETAIL SPECIFICATION SHEET CABLE, ELECTRICAL, -20 °C TO+105 °C, TYPES LSTCJU AND LSTCTU.pdf
MIL-DTL-24643/22E:2009 DETAIL SPECIFICATION SHEET CABLE, ELECTRICAL, -20 °C TO +90 °C, 5000 VOLTS, TYPE LS5KVTSGU.pdf
MIL-DTL-24643/24C:2009 DETAIL SPECIFICATION SHEET CABLE, ELECTRICAL, -20 °C TO +150 °C, TYPES LSTCJX, LSTCKX, LSTCTX, LSTCJXN, LSTCKXN, AND LSTCTXN.pdf
MIL-DTL-24643/25F:2009 DETAIL SPECIFICATION SHEET CABLE, ELECTRICAL, -20 °C TO +150 °C, TYPE LSPI.pdf
MIL-DTL-24643/26F:2009 DETAIL SPECIFICATION SHEET CABLE, ELECTRICAL, -20 °C TO +150 °C, 600 VOLTS TYPES LSDPS, LSTPS, LSFPS, LS7PS, LSDPSN, LSTPSN, LSFPSN, AND LS7PSN .pdf
MIL-DTL-24643/19F:2009 DETAIL SPECIFICATION SHEET CABLE, ELECTRICAL, -20 °C TO +105 °C, 1000 VOLTS, TYPE LS6SGU.pdf
MIL-DTL-24643:28F/2009 DETAIL SPECIFICATION SHEET CABLE, ELECTRICAL, -20 °C TO +90 °C, TYPE LS1S50MU .pdf
MIL-DTL-24643.29E:2009 DETAIL SPECIFICATION SHEET CABLE, ELECTRICAL, -20 °C TO +90 °C, 300 VOLTS, TYPE LSMU (INCLUDING VARIATION LSMUS) .pdf
MIL-DTL-24643/30F:2009 DETAIL SPECIFICATION SHEET CABLE, ELECTRICAL, -20 °C TO +90 °C, TYPE LS1SWU.pdf
MIL-DTL-24643/27F:2009 DETAIL SPECIFICATION SHEET CABLE, ELECTRICAL, -20 °C TO +90 °C, 600 VOLTS, TYPE LS2AU.pdf
MIL-DTL-24643/31F:2009 DETAIL SPECIFICATION SHEET CABLE, ELECTRICAL, -20 °C TO +90 °C, TYPE LS2SU, (INCLUDING VARIATION LS2SUS) .pdf
MIL-DTL-24643/32F:2009 DETAIL SPECIFICATION SHEET CABLE, ELECTRICAL, -20 °C TO +90 °C, TYPE LS2SWAU.pdf
MIL-DTL-24643/33F:2009 DETAIL SPECIFICATION SHEET CABLE, ELECTRICAL, -20 °C TO +90 °C, TYPE LS2SWU.pdf
MIL-DTL-24643/34F:2009 DETAIL SPECIFICATION SHEET CABLE, ELECTRICAL, -20 °C TO +90 °C, 300 VOLTS, TYPE LSMS.pdf
MIL-DTL-24643/35D:2009 DETAIL SPECIFICATION SHEET CABLE, ELECTRICAL, -20 °C TO + 90 °C, TYPE LS3SU (INCLUDING VARIATION LS3SUS).pdf
MIL-DTL-24643/36F:2009 DETAIL SPECIFICATION SHEET CABLE, ELECTRICAL, -20 °C TO +90 °C, TYPE LS3SWU (INCLUDING VARIATION LS3SWUS).pdf
MIL-DTL-24643/37F:2009 DETAIL SPECIFICATION SHEET CABLE, ELECTRICAL, -20 °C TO +90 °C, TYPE LS3U.pdf
MIL-DTL-24643/38F:2009 DETAIL SPECIFICATION SHEET CABLE, ELECTRICAL, -20 °C TO +90 °C, 600 VOLTS, TYPE LSECM.pdf
MIL-DTL-24643/39F:2009 DETAIL SPECIFICATION SHEET CABLE, ELECTRICAL, -20 °C TO +90 °C, TYPE LS1S75MU.pdf
MIL-DTL-24643/40F:2009 DETAIL SPECIFICATION SHEET CABLE, ELECTRICAL, -20 °C TO +90 °C, TYPE LS1SMU.pdf
MIL-DTL-24643/41D:2009 DETAIL SPECIFICATION SHEET CABLE, ELECTRICAL, -20 °C TO +90 °C, TYPE LS1SAU.pdf
MIL-DTL-24643/31E:2005 DETAIL SPECIFICATION SHEET CABLE, ELECTRICAL, TYPE LS2SU (INCLUDING VARIATION LS2SUS).pdf
MIL-DTL-24643/43F:2009 DETAIL SPECIFICATION SHEET CABLE, ELECTRICAL, -20 °C TO +90 °C, 600 VOLTS, TYPE LS2SJ, LS3SJ, AND LS4SJ.pdf
MIL-DTL-24643/44F:2009 DETAIL SPECIFICATION SHEET CABLE, ELECTRICAL, -20 °C TO +90 °C, 600 VOLTS, TYPE LS3SF.pdf
MIL-DTL-24643/45F:2009 DETAIL SPECIFICATION SHEET CABLE, ELECTRICAL, -20 °C TO +90 °C, TYPE LS2U.pdf
MIL-DTL-24643/16F:2009 DETAIL SPECIFICATION SHEET CABLE, ELECTRICAL, -20 °C TO +105 °C, 1000 VOLTS, TYPE LSTSGU.pdf
MIL-DTL-24643/46F:2009 DETAIL SPECIFICATION SHEET CABLE, ELECTRICAL, -20 °C TO +90 °C, TYPE LS2WAU.pdf
MIL-DTL-24643/42D:2009 DETAIL SPECIFICATION SHEET CABLE, ELECTRICAL, -20 °C TO +90 °C, TYPE LS1SU.pdf
bubbler filling system - 鼓泡填充系统(光纤坯棒加工设备的) (1) 投诉
