首页 > 柔性线缆
[机器人电缆] 汽车线用PP料,机器人用PP料
P:2018-06-27 08:23:10
联系方式    刘先生:15051635221   微信同步
THERMOPLASTIC POLYPROPYLENE COMPOUND FOR WIRE AND CABLE INSULATION
Description
Propylplus 700 is a polypropylene and halogen free compound specially designed for those applications requiring superior thermo-mechanical properties, outstanding heat resistance and electrical properties with the presence of a mix of antioxidants and a metal deactivator.It can be used as primary insulation on computer, telephone and instrument wires. The properties of this compound comply with the requirements of VDE 0250, Part 215, type 9YI2 and CEI-EN 60811-4-2.
Property
Test method
Unit
Typical Value
Density
ISO 1183
g/cm3
0.90
Hardness at 15”
ISO 868
Shore D
61
Tensile strength (v = 50 mm/min)
ISO 527
N/mm2
28.0
Elongation at break (v = 50 mm/min)
ISO 527
750
Pressure test at 120°C
IEC 60811
< 50
Melt Flow Index (230 °C / 2.16 Kg)
ISO 1133
g/10 min
4.0
Volume Resistivity 20°C
ASTM D257 Electrodes
Ω∙cm
> 1 ∙ 1017
(Alternating Polarity Method)
Dielectric Constant (1 MHz)
2.28
<div>
</div><div>
</div><div>
</div>
dual shape core optical fiber - 双层芯光纤 (0) 投诉
P:2018-06-27 08:31:25
Description
Propylplus 703 is a polypropylene and halogen free compound specially designed for those applications requiring superior thermo-mechanical properties, outstanding heat resistance and electrical properties with the presence of a mix of antioxidants and a metal deactivator.It can be used as primary insulation on computer, telephone and instrument wires. The properties of this compound comply with the requirements of VDE 0250 Part 215 type 9YI2 , CEI-EN 60811-4-2 and UL 1581 Class 80°C.
Technical characteristics
Property
Test method
Unit
Typical Value
Density
ISO 1183
g/cm3
0.90
Hardness at 15”
ISO 868
Shore D
49
ISO 527
N/mm2
25.0
ISO 527
700
IEC 60811
< 50
ISO 1133
g/10 min
Ω∙cm
>1 ∙ 1016
2.26
metallographic test - 金相试验 (0) 投诉
P:2018-06-27 14:21:26
你这是什么牌号的<div>
</div>
continuous coiling - 连续成圈 (0) 投诉
P:2018-06-27 15:24:14
上面物性里 有的   700  和 703
extruded aluminium sheath - 挤制铝护套 (0) 投诉
