[HDMI] HDMI cable的問題
P:2007-10-29 13:51:04
請告知以下是什麼意思?
以下是關於HDMI features的說明,請告知粗體所代表的意思。謝謝!
Tested to pass 1080p!
CL2-rated for in-wall applications
Broadcast quality digital video, digital audio, and inter component control signals all in one compact, high-performance connection!
Three layers of shielding:
two 80%+ OFC copper braids and
one 100% overlapped Mylar® foil
provide complete immunity to environmental EMI and RFI
24-karat gold-plated connectors ensure superior signal transfer and a lifetime of maximum performance
Silver-solder construction eliminates the negative effects of dissimilar metals on the delicate digital signal
Nitrogen-injected dielectric and meticulous construction make this interconnect the perfect choice for the most demanding home cinema installations.
CSM - charge simulation method电荷模拟法 (0) 投诉
P:2007-10-29 21:53:24
CL2-rated for in-wall applications:CL2认证
provide complete immunity to environmental EMI and RFI:三层遮蔽:两层裸铜(OFC)编织 + 一层铝箔麦拉,以防EMI和RFI(电磁干扰).
银焊可以完全保证信号传输的完整性
氮化绝缘体和精密的结构设置,将是家庭影院的最好接口!
short wave - 短波 (0) 投诉
