首页 > 国外线缆
[问题求助] UL1569 18AWG是什么线规?
P:2007-10-22 09:21:00
UL1569 18AWG是什么线规?
另外,我看1015 18AWG有好几种线规,哪里有这方面的综合资料呢?
[芝麻开门了 在 2007-10-23 11:00:31 编辑过]
cable jointing manhole - 电缆接头入孔 (0) 投诉
P:2007-10-22 10:46:03
是UL758标准的电子线,在UL标准的Stylepage里有详细的规定。
profile rolling - 型材轧制 (0) 投诉
P:2007-10-22 10:51:31
UNDERWRITERS LABORATORIES INC.               APPLIANCE WIRING MATERIAL
Subj. 758        Section 1          Page 1569       Issued:  1972-09-26
                                     Revised:  2003-09-17
Style 1569      PVC Insulated Wire.
______________________________________________________________________________
Rating      80°C, 90°C or 105°C, 300 Volts.
Conductor        No. 30 through 2 AWG, stranded or solid.
and
Insulation                          Thermoplastic PVC
                                 Minimum         Minimum
                                 Average      Thickness at
                                Thickness       any point
                 AWG Size         mils            mils
                  30 - 10           15              13
                   9 -  2           30              27
Covering        Optional - PVC, minimum average thickness 9 mils,
            minimum thickness at any point 8 mils.
Standard        Appliance Wiring Material UL 758.
Instructions    Detailed Examination.
to UL             Physical Properties, Unaged, Class 43.
Representative    Spark Test.
UL           (4)  Detailed Examination.
*Counter-Check       (4)  Physical Properties.
Program     (4)  Heat Shock.
            (4)  Cold Bend.
            (4)  Deformation.
            (12) Horizontal Flame Test.
Marking      General.
Use         Internal wiring of appliances or electronic equipment
                where not subjected to movement or mechanical damage.
            Tag may also indicate the following, "600 Volts
            Peak for Electronic Use Only."
PPAP - Production Part Approval Process, 生产件批准程序 (0) 投诉
P:2007-10-23 07:46:18
就是:1569#18:导体34/0.178或者41/0.16,然后OD=2.05。然后额定电压300V,额定温度105。这样子讲很通俗吧?
silane coupling agent - 硅烷偶合剂 (0) 投诉
P:2007-10-23 11:00:01
导体结构上,标准没有具体要求,只要截面积达到以下要求即可!
另绝缘需要达到3楼的标准要求!
Size of conductor
AWG
Diameter of soild conductor
Cross-sectional area of stranded conductor
Nomianl
Minimum
Nomianl
Minimum
Mils
(mm)
Mils
(mm)
Mils
(mm)
Mils
(mm)
18
40.3
1.02
40.0
1.016
1620
0.823
1588
0.807
CDF - cross-section dust figure横截面粉末图像(法) (0) 投诉
P:2012-07-27 11:23:17
Ducts - 通道 (0) 投诉
