[SATA] UL2725 SATA
P:2007-10-27 11:32:20
UNDERWRITERS LABORATORIES INC. APPLIANCE WIRING MATERIAL
Subj. 758 Section 2 Page 2725 Issued: 1975-05-02
Revised: 2006-11-20
Style 2725 Electronic Cable.
______________________________________________________________________________
Rating 60°C or 80°C, 30 V.
Insulated Labeled or Complies with manufacturer's AWM Procedure.
Singles May include mixed sizes.
Conductor Two, three, or four parallel, or two or more
Assembly twisted insulated singles or groups of twisted singles
twisted together or groups of twisted singles may be laid
parallel to form flat or oval cable. Lay not specified.
Barrier layer and/or fillers optional. May employ a web extruded integrally with the jacket. Manufacturer shall
maintain a complete description of each assembly. Diameter
of assembly under jacket one inch maximum.
Shield Optional.
Jacket PVC, Class 43, 9 mils minimum average, 7 mils minimum at
any point, before and after ripping if a web is used.
Standard Appliance Wiring Material UL 758.
Instructions Detailed Examination.
to UL Tensile and elongation of jacket, unaged
Representative
UL (4) Detailed Examination.
Counter-Check (4) Tensile and elongation of jacket, unaged and aged
(4) Heat Shock
(4) Cold Bend
(4) Deformation
*Program (12) Horizontal Flame Test.
Marking General.
Use Internal wiring of electronic equipment in Class 2 systems
only.
fatigue resisting capacity - 耐疲劳能力,耐疲劳次数 (0) 投诉
