首页 > 国外线缆
[问题求助] 1617和1672两种规格有什么区别吗?
P:2007-10-19 16:51:08
请问在实验标准上这两种规格有什么区别吗?
还有就是耐温是多少?
谢谢了
clad fiber - 包层光纤 (0) 投诉
P:2007-10-19 22:22:20
是指ul1617 的电子线和ul1672的电子线的规格是否相同和它们的耐温是多少的问题吗
conductive channel black - 导电槽黑 CC (0) 投诉
P:2007-10-20 08:11:16
300V  6000v
cladding - 镀层;垫层;金属包层法(一种铜包钢线制造方法) (0) 投诉
P:2007-10-26 10:13:30
是啊!!!
300V     和6000V是知道,就是不知道还有没有其他的什么区别.
steel armour wire - 铠装钢丝 (0) 投诉
P:2007-10-26 12:42:41
UNDERWRITERS LABORATORIES INC.               APPLIANCE WIRING MATERIAL
Subj. 758       Section 1         Page 1617        Issued:  1974-01-31
                                                    Revised:  2003-08-13
Style 1617      Insulated Wire.
______________________________________________________________________________
Rating      105°C, 600 V.
Insulated       Labeled or complying with the manufacturer's AWM
Single      Procedure having a minimum rating of 105°C, 600 V.
Covering        PVC:  From 5 to 40 mils.
Standard        Appliance Wiring Material UL 758.
Instructions    Detailed Examination.
to UL
Representative  The designation of the style used as the insulated single
            shall be available and the UL Representative's tag shall
            indicate if the style is labeled.  If the single is not
            labeled, the appropriate follow-up tests shall be conducted.
UL          (4)  Detailed Examination
*Counter-Check  (12) Horizontal Flame Test.
Program
            If the insulated single is not labeled, the appropriate
            Follow-Up Tests shall be conducted.
Marking     General.
Use         Internal Wiring of Electronic Equipment.
bending block - 折刀 (0) 投诉
P:2007-10-26 12:43:40
Subj. 758        Section 1        Page 1672        Issued:  1975-10-24
                                    Revised:  2003-03-06
Style 1672      Insulated Wire.
Rating      105°C, 300 Volts.
Insulated       Labeled or complying with manufacturer's AWM Procedure
Singles     having a minimum rating of 105°C, 300 V.
Covering        PVC:  From 5 to 40 mils may be irradiated.
to UL       The designation of the style used as the insulated single
Representative  shall be available and the UL Representative’s tag shall
            conducted.
UL          (4)  Detailed Examination.
Program
Marking     General.
electroconductor - 电导体 (0) 投诉
P:2007-10-26 16:33:34
很可惜,老崔是超级版主,要不肯定要鼓励的啊,嘿,谢谢老崔的标准答案。
Waveconal cable - ceander cable (0) 投诉
P:2007-10-26 17:35:34
谢谢老崔的标准答案,鲜花一朵!
pre-annealer - 预退火炉 (0) 投诉
P:2007-10-27 10:07:19
资料很详细啊...
谢谢了....
Wiring Closet - 布线室 (0) 投诉
P:2007-10-28 21:40:19
可以上UL 网站上下摘的,任何活页都可以查到的.
blister - 结疤,疱疤,气孔,砂眼,局部隆起;起泡,起皮 ;发泡剂 (0) 投诉
P:2007-10-31 13:15:57
^_^
都是同一溫度等級
test method on electric cables under fire conditions - 电缆燃烧试验方法 (0) 投诉
P:2007-11-28 17:56:46
真的很谢谢大家哦
sioplas - 硅烷交联聚乙烯 (0) 投诉
P:2007-12-02 16:27:12
顶了.....
water cure - 水硫化,热水硫化;温水交联 (0) 投诉
P:2007-12-11 14:52:53
我现在可以在网上看到了,,,
真的很多谢各位哦
CGF - Canon Grand Fair佳能大型博览会<主要展出高科技及电脑等先进产品> (0) 投诉
P:2008-01-31 15:18:57
1617和1672的導體結構是一樣的嗎?
state-of-the-art laser marking equipment - 现代化激光标志设备 (0) 投诉
