首页 > 国外线缆
[问题求助] 急求ul2990的性能参数,导线结构
P:2007-10-19 14:16:57
在线等答案,很急,谢谢大家了
loose buffer jacket - 松包缓冲套(光纤的) (0) 投诉
P:2007-10-19 14:29:56
UNDERWRITERS LABORATORIES INC.              APPLIANCE WIRING MATERIAL
Subj. 758     Section 2     Page 2990        Issued:  1979-04-11
                                Revised:  2003-03-20
Style 2990    Electronic Cable.
______________________________________________________________________________
Rating     80°C, 30 V.
Insulated     No. 40 AWG minimum.  Labeled or complying with
Conductors    Manufacturer's AWM Procedure having a minimum rating of
           80°C.
Assembly      Consists of two or more conductors, twisted pairs or
           groups of twisted conductors twisted together.  The
           conductors or groups of conductors may be laid parallel
           forming a flat, oval or round cable.  The lay of the
           conductors is not specified.  A barrier layer and/or fillers
           are optional. ______________________________________________________________________________
Covering      (Optional)  A 6 mil or heavier PVC covering may extruded
           over the conductor assembly.
Shield     Optional.
Jacket     PVC - Class 43
                     THICKNESS (mils)
             #Dia. of Cable                 Minimum
              Under Jacket       Minimum        at any
               in Inches          Average         point
              0.700 or less      30         24
           # - Major dia if cable is flat or oval.
                            (Continued on Page 2990A)
Subj. 758     Section 2     Page 2990A       Issued:  1979-04-11
                                Revised:  2003-03-20
Standard      Appliance Wiring Material UL 758.
Instructions  Detailed Examination.
to UL
Representative    The designation of all Styles of the individual conductors
           used making up the cable assembly shall be available, and
           the UL Representative's tag shall indicate if the Style
           is labeled or not.  If they are not labeled, the
           appropriate Follow-Up Tests shall be conducted.
UL         (4)  Detailed Examination.
Counter-Check (4)  Flexing.
*Program      (12) Cable Flame Test on Completed Cable.
           If the insulated Styles are not labeled, the appropriate
Marking       General.
           "Low voltage computer cable" may be printed on jacket
           surface.
Use       Internal Wiring or External Interconnection of Electronic
           Equipment, class 2 circuits only.
MACNET - multi-access communication network多接入通信网络 (0) 投诉
P:2007-10-19 14:40:29
38+1d对
BSHR - bidirectional self-healing ring双向自愈环 (0) 投诉
P:2007-10-19 15:07:56
楼主做的是不是IEEE 1284线材?
multi-position pay-off - 多位放线装置,多位置放线装置 (0) 投诉
P:2007-10-19 16:38:31
对的 你那有这方面的材料么?
polypyrrolone - 聚吡咯酮(可用作航空导线高温绝缘材料的基料) (0) 投诉
P:2007-10-19 18:16:16
只有惠盈的测试规范
cellular PE-insulated wire - 泡沫聚乙烯绝缘线 (0) 投诉
P:2007-10-19 18:34:47
我现在是想做那种线
Mating Force - 插入力(日) (0) 投诉
P:2007-10-21 16:31:21
继续征求 UL2900线的结构
irradiation cross-linking - 辐照交联 (0) 投诉
P:2007-10-22 09:25:59
yun,什么都没有呢,你也学习
impregnating tank - 浸渍罐,浸渍槽 (0) 投诉
P:2007-10-22 10:19:38
谢谢tanhy,请问那位有38P+1P的结构及电气性能。急需
let-off apparatus - 放线装置 (0) 投诉
P:2007-10-22 10:20:31
2L不是给答案了吗
combined drawing line - 综合拉丝生产线 (0) 投诉
P:2007-10-23 12:41:12
继续征求ul2900 38+1P 线的物理结构和电气性能,很需要
rupture - 破裂,断线;绝缘击穿 (0) 投诉
