首页 > 专业英语|国际贸易
[有奖翻译] 增集电线电缆专业英语词汇
P:2008-03-29 11:51:26
| 电线电缆结构设计 | |||
| 序号 | 英文全称 | 中文名称 | 英文缩写 |
| 1 | Aluminum Mylar | 铝箔麦拉 | AL/mylar |
| 2 | Abrasion Resistance | 耐磨 | |
| 3 | Adhesion | 附着力 | |
| 4 | Aging | 老化 | |
| 5 | America Wire Gauge | 美国线规 | AWG |
| 6 | Braid | 编织 | |
| 7 | Bunch Strand | 束绞 | |
| 8 | Bend | 弯曲 | |
| 9 | Brittle Point | 脆点 | |
| 10 | Cable | 电缆(多芯线) | |
| 11 | Cabling | 芯线绞合 | |
| 12 | Capacitance | 电容 | |
| 13 | Coaxial | 同轴线 | |
| 14 | Cold Resistance | 耐寒性 | |
| 15 | Concentric Stranding | 同心绞 | |
| 16 | Conductor | 导体(线) | |
| 17 | Cord | 花线 | |
| 18 | Crack | 开裂 | |
| 19 | Cross Section Area of Conductor | 导体截面积 | |
| 20 | Clear Mylar | 透明麦拉 | |
| 21 | Coverage | 遮蔽率 | |
| 22 | Density | 比重 | |
| 23 | Diameter | 直径 | |
| 24 | Distance of Conductor | 导体间距 | |
| 25 | Drain | 地线 | |
| 26 | Durability | 耐久性 | |
| 27 | Environmental test | 环境试验 | |
| 28 | Enameled Copper wire | 漆皮铜丝 | |
| 29 | Extrusion Grade | 挤出级 | |
| 30 | Fatigue | 疲劳 | |
| 31 | Filler | 填充物 | |
| 32 | Film | 薄膜 | |
| 33 | Fire Resistance | 阻燃 | |
| 34 | Flexible Copper | 软铜线 | |
| 35 | Flexural Strength | 抗折强度 | |
| 36 | Foamed | 发泡 | |
| 37 | Hardness | 硬度 | |
| 38 | Impedance | 阻抗 | |
| 39 | Insulation | 绝缘体 | |
| 40 | Inner Diameter | 内径 | |
| 41 | Injection Grade | 注塑级 | |
| 42 | Item | 项目 | |
| 43 | Jacket | 外被 | |
| 44 | Lay of Wire | 芯线绞距 | |
| 45 | Lay of Strand | 导体绞距 | |
| 46 | Material | 材料 | |
| 47 | Melt Point | 熔点 | |
| 48 | Melt Flow Index | 熔融指数 | |
| 49 | Non-migration | 非移性 | |
| 50 | Non Halogen | 无卤 | |
| 51 | Nylon | 尼龙 | |
| 52 | O.D of Strand Conductor | 导体绞合外径 | |
| 53 | Overlapping | 重叠率 | |
| 54 | Overall Diametre(Outer Diameter) | 外径 | |
| 55 | Polyethlene | 聚乙烯 | PE |
| 56 | Polypropylene | 聚丙烯 | PP |
| 57 | Polyurethane | 聚亚安酯 | PU |
| 58 | PolyvinylChloride | 聚乙烯 | PVC |
| 59 | Polyester Type | 聚酯型 | |
| 60 | Polyether Type | 聚醚型 | |
| 61 | Resistance | 电阻 | |
| 62 | Rigidity | 硬度 | |
| 63 | Rubber | 橡胶 | |
| 64 | Salt Spray Test | 盐雾实验 | |
| 65 | Scratch Resistance | 抗刮性 | |
| 66 | Separator | 隔离层 | |
| 67 | Shield | 遮蔽 | |
| 68 | Solid Copper | 硬铜线 | |
| 69 | Specific Gravity | 比重 | |
| 70 | Specification | 规格说明 | |
| 71 | Spiral | 缠绕(螺旋形) | |
| 72 | Spiral Shield | 缠绕隔离 | |
| 73 | Strand Copper | 多股铜 | |
| 74 | Stranded | 绞线 | |
| 75 | Tear Strength | 撕裂强度 | |
| 76 | Tensile Strength | 抗张强度 | |
| 77 | ThermoPlastic Rubber | 热缩性橡胶 | TPR |
| 78 | Thermoplastic Elastomers | 热塑性弹性体 | TPE |
| 79 | Thermoplastic Polyester Ester Elastomers | 聚酯型热塑性弹性体 | TPEE |
| 80 | Thermoplastic Vulcanizate | 热塑性硫化橡胶 | TPV |
| 81 | Thermoplastic Polyurethane | 热可塑性聚氨酯 | TPU |
| 82 | Thick of Insulation | 绝缘皮厚度 | |
| 83 | Thick of Insulation Between Conductor | 导体间的绝缘厚度 | |
| 84 | Thickness | 厚度 | |
| 85 | Tinned | 镀锡金属 | |
| 86 | Tinned Copper | 镀锡铜线 | |
| 87 | Tinned Solid Copper | 镀锡软铜线 | |
| 88 | Tinner Annealed Copper | 镀锡软铜线 | |
| 89 | Tinsel | 铜箔丝 | |
| 90 | Tissue Paper | 棉纸带 | |
| 91 | Wire | 单芯线 | |
| 92 | Water Absorption Rate | 吸水率 | |
| 93 | Weather Resistance | 耐候性 | |
管理员 奖励 100 金币,.2 声望,于 2009-3-20 21:14:03 原因:核实大部分词库内无。
lower stripper - 下脱料板 (0) 投诉
99
