[市内话缆] China High Speed Gate
P:2018-02-24 12:59:01
| Fingerprint access control high speed barrier Model No: SZAT-T02 Descrition: The speed gate is part of the entrance control system, which is one of the important parts of the modern entrance and exit control. The door wing is driven by the control system, automatically opens and closes, and the operation mode can be programmed by setting up. As long as the entrant is authorized, the door opens automatically. After the delay is closed, the time delay can be adjusted. Working principle: The door is driven by the control system, automatically opens and closes, and the operation mode can be programmed by setting up. As long as the entrant is authorized, the door opens automatically. After the delay is closed, the time delay can be adjusted. Technical parameter: Material:304 drawing stainless steel Cover thickness:1.5mm Cabinet thickness:1.2mm External Dimension:1400*141*1040mm Arm length≤300mm Channel width:≤600mm Gate opening and closing time:0.4S Our service ● Reply within one working days. ● OEM & ODM are available. ● Protection of sale areas for you. ● Delivering the goods by air,or sea or mail as to your requests. ● Providing professional technical support of consulting,training and product upgrade service for a long time.China High Speed Gate website:http://www.--chinesedetector.com/barrier-gate/high-speed-gate/ |
AC - analog computer模拟计算机 (0) 投诉
