[技术资料] Thrust Ball Bearings suppliers
P:2018-01-16 14:12:34
Thrust Ball Bearing 51411
1. Single direction thrust ball bearings: consist of two washers with raceways and balls guided b a cage. Washers have flat seating surfaces, and that is why they must be supported so that all balls can be evenly loaded. Bearings carry the axial load only in one direction. They are not able to carry radial forces.
2. Double direction thrust ball bearings: have two cages with balls between the central shaft washer and two houding washers with flat seating surfaces. The shaft washer has raceways on both sides and is fixed on the journal. Bearings are able to carry only axial forces in both directions.
Thrust Ball Bearing Technical Parameters
Products nameThrust Ball Bearing 51411
ID*OD*W(mm)55x120x48mm
MaterialChrome steel (Gcr15),High Carbon Steel-GCR11,Stainless Steel 440C,304,316
ClearanceC0,C1,C2,C3,C4,C5
Noise LevelEMQ V1 Z2, EMQ V2 Z3, EMQ V3 Z4, EMQ V4
ApplicationFan,Bike,Auto,Textile machine, Pump,Agricultural machinery,Machine tool...
Delivery TimeSmall Order:3-5 days after receiving your payment
Large Order:6-15 days after receiving your payment
Types:
    In terms of thrust ball bearings, our company can supply different types.
    Micro thrust ball bearing
    Single-direction thrust ball bearing;
    Double-direction thrust ball bearing;
    Single-direction thrust ball bearing with spherical seat washer
    29 series thrust ball bearing
    Single-direction thrust angular contact ball bearing
Thrust Ball Bearing stock:
Related thrust ball bearings:
51100 51101 51102 51103 51104 51105 51106 51107 51108 51109 51110 51111 51112 51113 51114 51115 51116 51117 51118 51120 51122 51124
Company information:
SDVV BEARING GROUP CO.,LTD is a professional bearing manufacture and famous brand bearing agent all over the world. Our continued to effort in the bearing field for over thirty years. We insist on the "quality first, credit first" business ideas. Our own brand is SDVV made in Germany. Mainly brand are Sweden SKF Bearing, Japan NSK Bearings, NTN bearings, KOYO bearings, FYH Bearing, NACHI Bearing, USA TIMKEN Bearing, Germany FAG Bearing, INA bearing. Chinese brands: Harbin HRB bearings, Wafangdian ZWZ bearings, Luoyang LYC bearings, and other major brands.
Why choose us:
  1) Professional Sales Team
2) Wide products range: Until now, we have almost all types of bearings, thus enabling us to be one of the largest bearing suppliers in the world.
3) Large stocks: we have abundant item numbers in stock, so we can delivery to you at once at your request.
4) Good quality and reasonable price: In accordance with ISO standards, we have professional Q/C staff, precision testing instruments and internal inspection system, the quality control is implemented in every process from material receiving to products packaging to ensure our bearings quality.
5) Rich experienced team: we own 22 technology departments and 116 workers, so we can satisfy your requirement
6) For original thrust ball bearings, we can provide Certificate of Origin and COO from Chamber of Commerce.
Packaging&shipping:
Packaging of thrust ball bearing:
1. Industrial packaging: plastic bag/plastic tube + kraft paper + carton + plywood pallets
2. Commercial packing: 1pc/plastic bag + color box + carton + plywood pallets
3. As the clients' requirement
Shipping:
DHL, FEDEX, TNT,ARAMEX
By SEA
By AIR
Certificates:
SDVV bearing has certificates,such as: authorized certificate,quality certificate,COC,ISO and so on.
Exhibition&customers:
With high quality and competitive price,our SDVV bearings has attracted customers from different countries,such as America,Mexico,Colombia,Dubai,Saudi Arabia and so on.
Feedback from customers:
Why so many customers like our products?
1.Quality is very good.
2.Our service is good,and they like to communicate with us.
3.They feel relaxed and happy when talking with us.
4.Price is very good.Thrust Ball Bearings suppliers
website:http://www.--1-bearing.com/ball-bearings/thrust-ball-bearings/
reeling drum - 收线盘 (0) 投诉
