首页 > 国外线缆
[问题求助] 哪位有UL21283 的标准资料?
P:2018-01-05 11:17:46
哪位大神有UL21283 的标准资料?请求共享一下
work - 加工,工程,作业;制品 (0) 投诉
P:2018-01-05 20:15:08
APPLIANCE WIRING MATERIAL
Subj.758 Section 2 Page 21283 Issued:2003-09-05
Revised:2011-09-07
Style 21283Multiconductor Cable with Extruded non-integral jacket
Rating80 deg C, 30 Vac, Horizontal flame.
Conductor40 AWG min. solid or stranded round, tinned or bare copper.
InsulationLabeled or complying with manufacturer's AWM Procedure.
AssemblyConsists of two or more conductors, twisted pairs or groups of twisted conductors twisted together. The conductors or groups of conductors may be laid parallel forming a flat, oval or round cable. The lay of the conductors is not specified. A barrier layer and/or fillers are optional. Manufacturers shall maintain a complete description of each assembly. May use same or mixed AWG size.
ShieldOptional. Over one or more of the insulated conductors or between the conductor assembly and the optional covering.
CoveringOptional. Extruded FRPE or extruded PVC covering over the conductor assembly, 5 mils minimum thickness at any point.
JacketExtruded FRPE, 12 mils min average thickness, 10 mils minimum thickness at any point.
StandardAppliance Wiring Material UL 758.
MarkingGeneral.
UseInternal wiring of electrical equipment.
UL and the UL Logo are trademarks of UL LLC © 2018
reevinghead - 高速同心式穿线头 (0) 投诉
P:2018-01-15 11:11:18
谢谢<div>
</div>
ad hoc committee - 特设委员会 (0) 投诉
