[供应信息] High quality accelerometer transducer
P:2017-12-05 09:17:02
Standard High Stability Sensor
Model: CA-YD-122
Features:
High stability
Wide frequency range
Suitable for calibrate sensors by back to back type
Dimensions
Temperature Response
Frequency Response
Specifications:
Sensitivity(20±5℃)1.2 pC/g
Measurement Range(pk)1000 g
Max Transverse Sensitivity≤3 %
Frequency Response(±5%)5~5000 Hz
Mounting Resonant Frequency30,000 Hz
Operating Temp. Range-40~+150 ℃
Temperature Response See Graph
Transient Temperature Response20 mg/℃(0.3Hz)
Magnetic Sensitivity1.5 g/T
Base Strain Sensitivity0.2 mg/με
Case Isolation>109 Ω
Capacitance~1000 pF
MountingM5
Sensing ElementBST
Sensing GeometryShear
Case MaterialStainless steel
Weight38 g
OutputSide L5
Accessories
CertificateCalibration parameter, frequency response
M8, M5/M8 Stud, Protective capEach one
L5/L5 STYV-1(2m)one
Recommend Charger AmplifierYE5852
CE Certification:
Sinocera Piezotronics, INC is professional as one of the credible standard high stability sensor manufacturers and suppliers in China. Our standard high stability sensor has CE certification and it is sold at a competitive price. And we have a professional factory at your service. Come and buy our high-quality products.High quality accelerometer transducer
website:http://www.--china-yec.net/sensors/accelerometer/
rural distribution wire - 农用配电线;农村电话线 (0) 投诉
