首页 > 求购信息
[求购信息] N Flange Mount RF Connector supplier
P:2017-11-30 12:40:02
N Male/Female Flange Mount Terminal Solder Type Connector:
RF Connector Specification Sheet:
Applicable Standard:
CECC 22210, IEC 60169-16, MIL-C-39012
Configuration:
■ N Female/Male Available;  ■ Flange Mount Solder Attachment Type
■ Either Powder Coating or Not Available ■ Length and Flange Dimension Customized
■ 500 hours Salty Spray Test■ Low VSWR & PIM Performance
Application:
■ Microwave Telecom System■ RF Passive Components
Description:
N connectors have been around since the 1940s and are used for a wide range of applications. The design of this type of connector gives it certain advantages over other microwave connectors, including a secure threaded connection and the ability to operate in poor weather environments.
N connectors can handle up to 11 GHz, and even 18 GHz in some precision versions. With such a wide performance band they have become the go to choice for most high quality antenna set ups. These connectors take only a few seconds to attach and can be tightened by hand. You will find N connectors in use in a variety of RF applications, including instrumentation, mobile base stations, radar, cell amplifiers, and more.
N Female/Male Flange Mount Solder Type Connector are wildly used in Microwave Telecom System and on RF Splitter, Filter, Combiner, and Duplexer Passive Components. With easy flange mount and solder attachment methods, the N type 4 Hole Flange Mount Connector enables to create an external connection media on customer product to realize signal transmission and communication, which can be used in a variety of panel mount application.
Technical Data:
Material Characteristics:
NO.PartsMaterialPlatingNotes
1PINTin BrassSilver plated******
2InsulatorPTFE************
3BodyBrassCuSnZn plated
/Powder Coating******
4GasketSilicon Rubber************
Environmental & Technical Characteristics:
NO.ItemsParametersNotes
1Temperature range-40~+85oC******
2Impedance50Ω******
3FrequencyDC~11 GHz******
4VSWR≤1.15******
5PIMD≤-155dBc******
6Durability500 cycles******
We can provide rich types of N flange mount 4 hole connector either male or female type. Plating can be selected by customers. Usually, the N type 4 hole flange mount connector is tri-alloy plating. To have better anti-corrosion performance, powder coating is often used.
Company profile:
HUAJIAN Electronics has been engaged in connection industry since 2001, with more than 17 year experience, HUAJIAN has developed to be a professional RF Connector manufacturer.
We now have 200 employees, 10% of whole are engineers. In the past years, we kept 15%~20% increasing rate.
Our main export market includes: Europe, North America, South-East Asia and Mid-East, our experienced international business team will give you best service and quick response.
Delivery Details:
FOB Port: Shanghai, Yiwu, Weihai
Lead Time: 7~10 days after payment or order confirm.
Shipping Method: by Air, by Sea or international express such as FedEx, DHL.
If you're looking for N type male/female low pim epoxy powder coating square flange with panel fixed anti-corrosion 1000hrs salty spray test terminal solder type connector for rf load, rf splitter, combiner,duplexer,filter passive components, welcome to buy the factory price products in stock from our factory. As an experienced China manufacturer, we will offer good after-sale service and fast delivery.N Flange Mount RF Connector supplier
website:http://www.--rfconnector-china.com/rf-coaxial-connector/n-connector/
dereeler - 放线装置 (0) 投诉
P:2017-12-02 11:41:56
Now, we need 4.3-10   female connector  with  flang ,any information ?
high molecular wt.polybenzimidazole - 高分子量聚苯并咪唑 (0) 投诉
