[供应信息] resistor power
P:2017-11-30 11:29:57
| 200KW Indoor Load Bank High Power Cabinet with 0.5g Viberation We ffers high power, high voltage and high quality 200KW power cabinet. Pak Heng Resistor company is a susseccful and honesty manufacturer and supplier. We have devoted ourselves to power cabinet for many years, we will provide good service and competetive price to you. Hope we can built long-term relationship.Product Introduction: PRU series products are made of rimple resistors,apply to the transducer of braking equipments,testers,elevators,crane of high power and high current.The operating voltage is DC 500v-2000v. Rated power is 20KW-200KW. Techinical Parameters: 1、Power range:20KW-200KW 2、Voltage range:0.5KV-2KV 3、Resistance value range:0.5R-100R 4、Withstand voltage:AC2.5KV-5KV/1min 50Hz 5、IP Grade:IP20-IP23 6、Vibration:0.5g 7、Temperature excursion:≤400ppm/℃ 8、Transfer fluid material:0Cr25AL5/Ni80Cr20 9、Advantage:High Power,High voltage 10、Disadvantage:Weak antiknock characteristic Apperance Installation Size: typePower(kw) dimension(mm)Terminal Weight(kg) Cable(mm2) Combination WDHH1D1W1 PRU20700500700785342615M660108×2.5KW 30 700500900985342615M673.41612×2.5KW 40 70050011001185342615M686.82516×2.5KW 50 70050013001385342615M6100.22520×2.5KW 60 70050015001585342615M6113.63524×2.5KW 70 70050017001785342615M61275028×2.5KW 80 70050018001885342615M6138.55032×2.5KW 100 70050020002085342615M6165.35040×2.5KW 120 70050022002285342615M6192.15048×2.5KW 200 70050020002085342615M6330.6752×100KW PakHeng Electronics is one of the leading 200kw indoor load bank high power cabinet with 0.5g viberation manufacturers and suppliers in China, offering the free sample and competitive price. Welcome to wholesale the high quality bulk resistors made in China from us. It if of good performance and high safety.resistor power website:http://www.--resistors-pakheng.com/ceramic-tube-resistors/flat-type-ceramic-tube-resistors/ |
commitment - 委托事项, 许诺, 承担义务 (0) 投诉
