[供应信息] ceiling panels materials
P:2017-11-17 15:47:48
1. Product code: PA6012T2. Color: White, RAL color available3. Dimension: 600 x 1200mm, custom made available4. Surface finishing: Akzo Nobel electrostatic powder coating5. Material: Aluminum alloy6. Thickness: 0.6mm, custom made available7. Shape: Square, custom made available8. Edge profile: Straight edge9. Perforate: Perforated Ø1.8 diagonal, custom made available10. Warranty: 8-10 years
Specification1, Type: Clip - in Square Ceiling2, Material: Aluminum alloy3, Thickness: 0.6mm, custom made available4, Surface Coating: Akzo Nobel electrostatic powder coating5, Size: 300 x 300mm, 300 x 600mm, 300 x 450mm, 300 x 1200mm, 400 x 400mm, 400 x 1800mm, 500 x 500mm, 600 x 600mm, 600 x 1200mm, 800 x 800mm; custom made available6, Color: White, subject to user demand
Features 1. Beautiful appearance, and various colors for choice;2. After fastening carriers, workmen can easily install ceiling tiles by hand3. High quality aluminum alloy inhibits red rusting, and can be used in nonmagnetic environment.4. Installation System is engineered and designed to fit and provide a finish to coordinate with OUSILONG ceiling.5. Custom made metal walls available to coordinate with ceilings and other interior / exterior finishs;6. Nice pigment wet ability, no static, non - flammable;7. Fireproof, anti - corrosion, thermo stability and good weather resistance;8. Certificate: ISO9001:2008, ISO14001:2004, CE, SONCAP, GB/T28001-2011, SGS Test etc;
Accessories Clip - in square ceiling was derived from Germany with advanced & unique production technology, which is the superior product of OUSILONG with professional mold design, even panel surface, distinct edges & lines, and clear & concise. All of these create a pleasant visual space. It has multiple accessibility options which are custom made to support the use of the clip - in ceiling.
Application OUSILONG always take “improving the human living environment” as her own duty, devoting to invent eco-friendly aluminum ceilings and other new products. With the philosophy of people oriented & good faith, by virtue of OUSILONG brand influence, sales network, and R&D capability, we’ll sustainably launch more safety, energy saving, ecofriendly and fashionable products to meet all customers’ needs.
Industrial and civil buildings, special buildings, building curtain wall, interior partitions, suspended ceiling, wall, airport, bus station, museum, opera house, exhibition hall, shopping centre, conference hall, bar etc.
Installation OUSILONG ceilings feature at fireproof, anti - corrosion, thermo stability and good weather resistance. The colors keep fresh for a long time. Many kinds of sizes are available. Matched with non - standard aluminum panel in installation, it will perform better. The installation of ceilings is simple, clean and produces very little waste. It’s the perfect choice for building decoration.ceiling panels materialswebsite:http://www.--ousilongceiling.com/ceiling/ceiling-tile/
repeater nylon - 中继站 (0) 投诉
