首页 > 专业英语|国际贸易
[翻译求助] 请您翻译-等截面平行集束架空绝缘电缆
P:2007-09-29 10:47:39
等截面平行集束架空绝缘电缆
neutral supported secondary cable - 中线支承二次回路用电缆,中性线支承二次回 路用电缆 (0) 投诉
P:2007-09-30 09:21:43
太复杂了吧,我看没人搞得定地 哈哈
special wire - 特种电线 (0) 投诉
P:2007-10-07 15:01:21
试一下,请指教:
equal-section parellel  aerial insulation cable with harness
e.h.p. - electric horsepower电动马力 (0) 投诉
P:2007-10-10 07:50:15
有点意思的 谢拉
scratch - 刮痕,刮伤,擦破 (0) 投诉
P:2007-10-12 15:59:04
平行集束架空绝缘电缆  应该是parallel bundle assembled aerial insulated cable 今天请教的高人 大家有何意见?
polystyrol - 聚苯乙烯(高频绝缘材料) (0) 投诉
P:2007-10-19 08:50:52
<DIV id=result_box dir=ltr>Such cross-section parallel cluster overhead insulated cable</DIV>
resin - 树脂,松香 (0) 投诉
P:2007-10-19 14:15:13
试一下 不合适的地方请多指教
uniform section parallel bundle-integrated overheah insulated cable
integrated messenger cable - 自承式综合电缆,自承式综合通信电缆 (0) 投诉
P:2007-11-10 08:33:02
到底谁才是对的啊
optical distribution cable - 配线光缆 (0) 投诉
P:2007-12-06 15:41:30
The constant section parallel beaming is built on stilts the insulation electric cable
field-strength - 场强 (0) 投诉
