首页 > 国外线缆
[问题求助] 请问UL1015 18#是什么结构呀?
P:2007-09-21 18:02:11
大家好 我是新手 做UL线刚学  请多指教
请问1015    18#是什么结构呀
[芝麻开门了 在 2007-10-10 10:25:04 编辑过]
testing - 试验,检验,测试 (0) 投诉
P:2007-09-21 18:27:55
有效导体面积0.75mm2(18AWG),以“单线数目/单线直径”表示,有16/0.254 mm;24/0.20 mm;30/0.18 mm;34/0.178 mm;41/0.16 mm等规格.
subzero temperature - 零下温度,负温度 (0) 投诉
P:2007-09-21 18:39:17
电压等级600V,温度等级105度.最小绝缘厚度0.69mm,平均厚度0.75mm.一般用34/0.178押成2.8mm.
header error control - 开销误差控制,信头误码控制 (0) 投诉
P:2007-09-21 19:27:51
这样不行的多看看标准
high-usage trumpet - 高利用率信息通路 (0) 投诉
P:2007-09-22 10:21:19
在论坛里面有相应的标准,全套的,先看看吧。
packet-switched network - 信息包交换网络 (0) 投诉
P:2007-09-22 12:02:11
在论坛里找一下活页看一下,
有很详细的介绍!
lecel 5 cable - 5类电缆 (0) 投诉
P:2007-09-22 22:56:44
THHN, MTW, THWN, AWM
Thermoplastic Insulated, Nylon Sheathed Heat, Moisture, Oil & Gasoline Resistant 600 Volt Copper
Product Description:
Alan Wire Type THHN or THWN conductors are primarily used in conduit as branch circuits in commercial or industrial applications, as specified by the National Electrical Code. Type AWM or MTW conductors are primarily used as appliance or machine tool wiring, as specified by the National Electrical Code.
Type THHN or THWN are available as stranded in sizes 14-4/0 AWG, and as solid in sizes 14-10 AWG. Stranded sizes 14-10 AWG are also rated as AWM or MTW. The conductors are soft-annealed, stranded or solid copper and are insulated with a tough, heat and moisture resistant polyvinyl chloride (PVC), over which a nylon (polymide) jacket is applied.
Specifications:
Alan Wire Type THHN or THWN or AWM or MTW meets applicable ASTM specifications, UL Standard 83, UL Standard 758, and UL Standard 1063. The conductors are Gasoline and Oil Resistant II, and have a voltage rating to 600 volts.
ConductorPVC Insulation Thickness (Mils)Nylon Jacket Thickness (Mils)Nominal O.D. (Mils)AmpacityApprox. Net Weight per MFTColor CodeStandard Package
Size AWGNo. Strands75?C THWN90?C THHN
**14Solid1541021515161AE
**12Solid1541192020241AE
**10Solid2041503030371BE
14191541121515161AE
12191541312020241AE
10192041653030371BE
8193052184550642B
6193052566570962CD
41940632585901552CD
3194063451001051903CD
2194063881151202353CD
1195074371301403003CD
1/0195074771501553703CD
2/0195075211751854653CD
3/0195075712002105703CD
4/0195076272302357204CD
250376087112552908505CD
3003760876628532010115CD
3503760881731035011725CD
4003760886433538013335CD
5003760894938043016535CD
60061709105142047519855CD
75061709112647553524625CD
A - 2000' Carton, Four 500' Spools Per Carton                          ** Not Suitable for MTW Applications
B - 1000' Carton, Two 500' Spools Per Carton
C - 500' Reel      D - 1000' Reel     E - 2500' Reel                            Other lengths available upon request.
Colors Available:
Color Code #1) Black, White, Red, Blue, Green, Orange, Yellow, Brown, Purple, Gray, Pink, Tan
 Color Code #2) Black, White, Red, Blue, Green, Orange, Yellow, Brown, Gray
 Color Code #3) Black, White, Red, Green
 Color Code #4) Black, Green
Some colors are subject to economic order quantity.
LOROMQA 奖励 0 金币,.05 声望,于 2007-10-9 18:38:55 原因:好资料!
FAN - flow analysis network流动网络分析(法)(一种分析挤出机头内塑料流动问题的有效方法) (0) 投诉
P:2007-10-05 16:54:00
想省钱 的 就 用 根数少的
inside micrometer - 内分卡 (0) 投诉
P:2007-10-06 15:27:59
UNDERWRITERS LABORATORIES INC.               APPLIANCE WIRING MATERIAL
Subj. 758     Section 1     Page 1015       Issued:  May 1, 1959
                                Revised:  Nov. 26, 2001
Style 1015    PVC Insulated Wire.
______________________________________________________________________________
Rating     80°C, 90°C or 105°C; 600 V ac, 750 V dc.
*Conductor    30 AWG - 2000 kcmil.
Insulation    PVC
                          Min. Avg.     Min at Any Point
*             Size           Mils           Mils
              30-9           30          27
               8,7            45          40
               6-2            60          54
              1-4/0              80          72
*             250-500 kcmil         95          86
*             550-1000 kcmil       110              99
*             1100-2000 kcmil      125             112
Standard         Appliance Wiring Material UL 758.
Instructions     Detailed Examination.
to UL            Physical Properties, unaged, Class 43.
Representative       Spark Test.
UL             (4)  Detailed Examination.
Counter-Check       (4)  Physical Properties, Class 43.
Program         (4)  Heat Shock.
             (4)  Cold Bend.
             (4)  Horizontal Flame Test.
              (4)  Deformation.
Marking         General.
Use          Internal Wiring of Appliances; or Internal Wiring of
             Appliances where exposed to oil at a temperature not
             exceeding 60 deg. C or 80 deg. C (whichever is                  applicable). Tags may also indicate the following: 2,500 V           peak - for electronic use only.
LOROMQA 奖励 0 金币,.05 声望,于 2007-10-9 18:37:09 原因:提供的资料很适用!
MFT - 1000呎之缩写。 (0) 投诉
P:2007-10-08 18:17:02
spiral elongation test - 螺旋伸长试验,螺旋形伸长试验(研究杂质对铜线可退火性影响的一种试验方法,由Olen于1955年提出,因此也称为Olen法) (0) 投诉
P:2007-10-09 18:38:30
9楼
你辛苦了!
inclusion - 杂质,夹杂物 (0) 投诉
P:2007-10-10 07:28:25
谢谢楼上的!
我是有这方面的资料,直接复制粘贴上去的
commissioning objeetive - 交付指标 (0) 投诉
P:2007-10-20 09:40:58
有没有人有中文的UL线材标准资料?
twin-layer - 双层(的),两层(的) (0) 投诉
P:2011-11-27 10:39:59
谢谢
transmitted echo - 伴流 (0) 投诉
