首页 > 连接器 插头附件
[连接材料] HR连接器 B2512 Terminal /Housing 间距:2.50mm
P:2015-11-23 17:10:12
<div style="top: 498px; left: 722px; width: 400px; height: 400px; display: block;" class="zoomdiv">
</div> <div class="introzone"> <div id="prodtitle">
B2512 Terminal / Vertical . Right Angle Housing 連接器</div> <div id="prop">間距:2.50mm
型號:B2512
</div> <div id="memo" class="memo" style="display:block">Current Rating: 3A AC, DC
Voltage Rating: 250V AC, DC
Temperature Range: -25 deg C ~ +85 deg C
Contact Resistance: 10m Omega Max.
Insulation Resistance: 1,000M Omega Min.
Withstanding Voltage: 800V AC/minute
</div> <div class="bshare-custom icon-medium-plus"> </div><div id="prop">
</div> </div>
</div> <div class="introzone"> <div id="prodtitle">B2512 Terminal / Vertical . Right Angle Housing 連接器</div> <div id="prop">間距:2.50mm
型號:B2512
</div> </div> 產品型號 | 文件格式 | 文件瀏覽 |
B2512 | PDF文檔 |
earth leakage breaker - 接地漏电断路器 (0) 投诉
