[问题求助] 根据下述要求,请问如何检测评价加强件的此项性能?
P:2015-09-14 11:44:55
  5.2. ADHESION PERFORMANCE
    5.2.1. For the Strength Member
             Mount a specimen such that a normal force at 11 Kg/mm² is maintained at the tangent point of the cable. There shall be no perceptible buckling, slippage or rupture of   the
 sheath and/or insulation over the strength member at any point when tested in accordance with Paragraph 7.2.2 of REA PE-7.
pneumatically-operated sensor arm - 气动传感臂 (0) 投诉
