首页 > 航空 铁路 船港
[船用电缆] BS 6883标准海洋工程及船用电缆,护套铠装中压阻燃电力&控制缆
P:2015-09-14 11:13:41
BS 6883和BS 7917标准海洋工程及船用电缆
应用
1.9/3.3KV和3.3/3.3KV HF-EPR绝缘SW2/SW4护套铠装船用阻燃电力&控制缆,中压橡胶绝缘电缆专为船舶和海上移动平台的固定布线而设计,适用于电力&控制应用。
标准
  • BS 6883
  • IEC 60332-3A 阻燃
  • IEC 60754-1; IEC 60754-2 腐蚀性
  • IEC 61034-2 烟密度
  • 冷弯和冲击(-40°C)(应要求提供)
  • CSA C22.2 No. 38-95(应要求提供)
结构
导体符合BS 6360/IEC 60228 cl.2的圆形多股镀锡铜丝
绝缘符合BS 7655 1.2标准的HF-EPR GP5
内护套符合BS 7655 2.6的无卤热固材料SW4或减少了卤素的热固材料SW2
铠装镀锌钢丝编织或镀锡青铜丝编织(单芯)
外护套符合BS 7655 2.6的无卤热固材料SW4或减少了卤素的热固材料SW2
机械和热性能
最小内部弯曲半径6×OD
温度范围-40℃ ~ +90℃
[atltech0 在 2015-9-14 11:15:41 编辑过]
skyscraper - 摩天大楼;高烟囱 (0) 投诉
P:2015-09-14 11:16:01
尺寸和重量
1.9/3.3KV
结构芯数×截面积标称绝缘厚度标称内护套厚度最小内护套外直径最大内护套外直径标称铠装丝直径标称外护套厚度最小外径最大外径近似重量
MM2MMMMMMMMMMMMMMMMKG/KM
1×102.21.110.211.90.31.314.216.2398
1×162.21.211.413.10.31.315.417.6499
1×252.21.213.014.80.31.417.119.5675
1×352.21.314.115.90.31.418.220.6793
1×502.21.315.317.20.31.519.622.4970
1×702.21.417.219.20.31.621.724.61269
1×952.41.519.421.90.31.724.227.21623
1×1202.41.621.323.80.31.726.029.11983
1×1502.41.622.825.40.451.828.431.62423
1×1852.41.724.827.40.451.930.634.32917
1×2402.41.827.530.30.452.033.537.33654
1×3002.41.930.033.20.452.136.240.14428
1×4002.62.033.837.10.452.340.344.85416
1×5002.82.237.641.10.452.544.549.26726
1×6302.82.341.245.20.452.648.453.68562
3×102.21.520.422.90.31.725.128.21052
3×162.21.622.825.30.31.827.730.81357
3×252.21.826.629.30.452.032.636.32032
3×352.21.828.431.20.452.134.638.52382
3×502.21.931.234.40.452.237.641.62936
3×702.22.135.338.70.452.442.146.73877
3×952.42.340.244.10.452.647.452.14995
3×1202.42.444.048.10.452.751.456.76118
3×1502.42.647.651.80.452.955.360.87284
3×1852.42.751.756.40.453.059.665.78750
3×2402.43.057.762.90.453.366.272.611118
3×3002.43.263.168.60.453.572.079.013531
3.3/3.3KV
1×103.01.212.013.70.31.416.118.4483
1×163.01.213.014.70.31.417.119.4579
1×253.01.314.716.70.31.519.121.5774
1×353.01.315.617.60.31.519.922.8885
1×503.01.417.019.00.31.621.524.41082
1×703.01.518.921.00.31.623.426.41377
1×953.01.520.623.10.31.725.328.41699
1×1203.01.622.525.00.31.827.430.52081
1×1503.01.724.126.80.451.930.033.62550
1×1853.01.726.028.60.452.032.035.73032
1×2403.01.828.731.80.452.134.838.73780
1×3003.01.931.234.40.452.237.641.54563
1×4003.02.134.738.10.452.341.345.85514
1×5003.22.238.441.90.452.545.350.06807
1×6303.22.442.246.20.452.649.454.68691
3×103.01.724.126.70.451.929.933.61404
3×163.01.826.529.20.452.032.536.21738
3×253.01.930.133.20.452.136.340.22314
3×353.02.032.135.40.452.238.542.92701
3×503.02.134.938.30.452.341.546.03278
3×703.02.238.942.70.452.545.850.54226
3×953.02.442.946.90.452.750.255.55297
3×1203.02.546.750.90.452.854.259.76442
3×1503.02.750.354.90.453.058.264.27631
3×1853.02.854.459.20.453.262.768.99158
3×2403.03.160.465.70.453.469.176.011526
deburring - 去毛刺,清理毛口,倒角 (0) 投诉
