[供应信息] C2505 2.50mm Pitch Terminal / Housing 连接器
P:2015-08-31 17:19:27
<div class="productpics"> <div id="preview"> <div class="jqzoom" id="spec-n1">
</div></div></div> <div class="introzone"> <div id="prodtitle">C2505 2.50mm Pitch Terminal / Housing 連接器</div> <div id="prop">間距:2.50mm
型號:C2505
</div> <div id="memo" class="memo" style="display:block">Current Rating: 3A AC, DC
Voltage Rating: 250V AC, DC
Temperature Range: -25 deg C ~ +85 deg C
Contact Resistance: 10m Omega Max.
Insulation Resistance: 500M Omega Min.
Withstanding Voltage: 1,500V AC/minute
Contact H.R for details.</div> <div class="bshare-custom icon-medium-plus"> </div><div id="prop">
</div> </div>
</div></div></div> <div class="introzone"> <div id="prodtitle">C2505 2.50mm Pitch Terminal / Housing 連接器</div> <div id="prop">間距:2.50mm型號:C2505
</div> </div> 產品型號 | 文件格式 | 文件瀏覽 |
C2505 | PDF文檔 |
vertical continuous vulcanising line - 立式连续硫化生产线 (0) 投诉
