[供应信息] HR灿达鸿儒连接器 B2011 Terminal / Vertical Housing
P:2015-08-17 17:04:08
B2011 Terminal / Vertical . Right Angle Housing 連接器
間距:2.00mm
型號:B2011
Current Rating: 2A AC, DC
Voltage Rating: 250V AC, DC
Temperature Range: -25 deg C ~ +85 deg C
Contact Resistance: 20m Omega Max.
Insulation Resistance: 1,000M Omega Min.
Withstanding Voltage: 800V AC/minute
間距:2.00mm
型號:B2011
[hrconn 在 2015-8-17 17:05:58 编辑过]
ideal - 理想, 完美的, 想象的, 观念的, 唯心论的 (0) 投诉
