[材料介绍] TPE UL电源线,过VW-1,耐油,产品通过UL认证。
P:2015-05-07 11:09:07
Table如有需求,请联系我,中广核三角洲,徐振13915772157
| Item | Unit | Standard | Typical | Testing Standard |
| Density | g/cm3 | 1.04±0.03 | 1.04 | ASTM D 792 |
| Hardness,15s | Shore A | 85±2 | 83 | ASTM D 2240 |
| 230℃×5kg,Melt Flow Rate | <,g/10min | 2 | 1.8 | ASTM D 1238 |
| 500mm/min,Tensile strength | ≥,MPa | 12 | 14 | ASTM D 412 |
| 500mm/min,Elongation at break | ≥,% | 200 | 374 | ASTM D 412 |
| Volume Resistance at20℃ | ≥,Ω·cm | 1.0×1015 | 3.4×1015 | IEC 60093 |
| Thermal aging | 136℃×168h(Temp. resistant grade 105℃) | |||
| TS retention | ≥,% | 75 | 110 | UL 1581 |
| EB retention | ≥,% | 75 | 78 | UL 1581 |
| Oxygen index | ≥,O2 % | 25 | 26.4 | ISO 4589 |
| V grade burning test | - | V0(6mm) | pass | UL 94 |
| Hot deformation variation (150℃×1H×2kg load) | % | <50 | 35 | UL 1581 |
| Thermal Shock(150℃×1H 30min) | - | No cracking | pass | UL 1581 |
| Cold bend(-40℃×4H) | - | No cracking | pass | UL 1581 |
| Oil resistant(902#oil) | 60℃×168h | |||
| TS retention | ≥,% | 75 | 94 | UL 1581 |
stress distribution - 电场分布,场分布,应力分布 (0) 投诉
