首页 > 专业英语|国际贸易
[翻译求助] water cooled cable
P:2007-09-03 12:45:56
1.what means water cooled cable?
2.How to translate"stranded around a rubber or a stainless steel spring depending on the equipment they will supply"
3.How to translate"the copper conducters benefit from an optimal direct cooling,the smallest diameter for water circulation being the inlet of ther cable"
Thank you a million!
loose tube fiberoptic cable - 松套管光缆,松包光缆 (0) 投诉
