[问题求助] TR型软铜线与TY型硬铜线的区别是什么
P:2006-09-15 14:33:57
GB3953电工圆铜线,里边有关于TR型和TY型铜线的区别!
GBT3953-83.pdf
管理员 奖励 0 金币,-.1 声望,于 2006-9-15 14:33:57
Equipment Cable - 设备线缆 (0) 投诉
P:2007-08-09 15:39:54
TR型软铜线与TY型硬铜线的区别除了化学成分不一样外还有抗拉强度、延伸率、电阻率都不一样
表1:抗拉强度和延伸率
| <DIV align=center> </DIV> | <DIV align=center>直径mm</DIV> | <DIV align=center>抗拉强度,N/mm2不小于</DIV> | <DIV align=center>伸长率,%不小于</DIV> | |
| <DIV align=center> </DIV> | <DIV align=center> TR </DIV> | <DIV align=center>6.0-35</DIV> | <DIV align=center>-</DIV> | <DIV align=center>40</DIV> |
| <DIV align=center> </DIV> | <DIV align=center>-</DIV> | <DIV align=center>35</DIV> | ||
| <DIV align=center> </DIV> | <DIV align=center>TY </DIV> | <DIV align=center>6.0-7.0</DIV> | <DIV align=center>370</DIV> | <DIV align=center>2.0</DIV> |
| <DIV align=center>>7.0-8.0</DIV> | <DIV align=center>345</DIV> | <DIV align=center>2.2</DIV> | ||
| <DIV align=center>>8.0-9.0</DIV> | <DIV align=center>335</DIV> | <DIV align=center>2.4</DIV> | ||
| <DIV align=center>>9.0-10.0</DIV> | <DIV align=center>325</DIV> | <DIV align=center>2.8</DIV> | ||
| <DIV align=center>>10.0-11.0</DIV> | <DIV align=center>315</DIV> | <DIV align=center>3.2</DIV> | ||
| <DIV align=center>>11.0-12.0</DIV> | <DIV align=center>290</DIV> | <DIV align=center>3.6</DIV> |
表2:电阻率
| <DIV align=center> </DIV> | <DIV align=center>状态</DIV> | <DIV align=center>体积电阻率ρ20,Ωmm2/m不大于</DIV> |
| <DIV align=center> </DIV> | <DIV align=center>TR</DIV> | <DIV align=center>0.01707</DIV> |
| <DIV align=center> </DIV> | <DIV align=center>0.01724</DIV> | |
| <DIV align=center> </DIV> | <DIV align=center>TY </DIV> | <DIV align=center>0.01750</DIV> |
| <DIV align=center> </DIV> | <DIV align=center>0.01777</DIV> |
</DIV>
barrier-layer - 阻挡层 (0) 投诉
