首页 > 国外线缆
[问题求助] UL标准系列电线电缆印字规范
P:2007-08-30 13:17:01
UL標准系列電線電纜印字規范
1. 常見印字方式有:
2. 印字標志間距:
3. 印字表面牢固性試驗:
  4. 印字內容
4.3多重電線(Multiple – rated Cables)的表面標識方法:
  4.4 AWM線材一般其基本構成包括:
5. 常規燃燒等級(印字標識簡介)
[辉熊 在 2007-8-30 16:37:53 编辑过]
unit-composed system - 单元组合装置 (0) 投诉
P:2007-08-30 13:25:04
不错的资料。希望继续努力
carrier multiplex communication - 载波多路通信 (0) 投诉
P:2007-08-30 19:11:24
密码是多少啊
Assembly Line - 组装生产线 (0) 投诉
P:2007-08-30 22:15:01
还有密码
lubricant powder - 润滑剂粉末 (0) 投诉
P:2007-08-31 08:30:53
不好意思,是“he”
A.P.U. - auxiliary power unit铺助电源设备 (0) 投诉
P:2007-09-22 12:01:05
很不错的恭喜,
谢谢!
low-windpressure conductor - 低风压导线 (0) 投诉
P:2007-09-24 10:56:02
有币才能看到呢, 我没有币
old cable recycling - (废)旧电缆再利用 (0) 投诉
P:2008-03-21 09:21:10
UL不是没有印字间距要求的吗?
phosphor bronze armouring tape - 磷青铜铠装带 (0) 投诉
P:2008-03-28 08:45:55
我也没币,看来要努力挣币
CDP - cresyldiphenyl phosphate磷酸甲苯-联苯酯 (0) 投诉
P:2008-03-31 15:35:22
47 Surface Marking of AWM
47.1 Surface marking is not required for appliance wiring material.
47.2 When surface marking referencing ²AWM² is used, the marking shall contain the following elements:
a) Wire/cable designation: ²AWM.²
b) Name of the organization responsible for the AWM, trade name, other applicable mark, or
file number. When the organization responsible for the AWM produces AWM in more than one
location, an additional distinctive marking shall be provided that identifies the specific
manufacturing location of the AWM.
Other markings such as wire size, number of conductors, and similar data, are determined to be in
compliance with this requirement when they are not confusing or misleading.
47.3 For a cable that contains a conductive polymeric shield, the jacket or marker tape shall be marked
²Conductive Shield,² ²Contains Polymeric Conductive Shield,² or equivalent.
TEC - thermal expansion coefficient热膨胀系数 (0) 投诉
P:2008-04-03 13:40:24
很好
earth conductor - 接地导体(GB) (0) 投诉
P:2008-05-28 15:52:43
本来是想下载的可下载的时候却提示:该文件已被删除或改名字
下载不到
hygroscopic insulating material - 吸湿绝缘材料 (0) 投诉
P:2008-06-09 19:06:26
high frequency - 高频 (0) 投诉
P:2008-06-10 01:55:55
很好,多谢了!
bus bar - 汇流排,母线 (0) 投诉
P:2008-06-23 17:54:40
下不了,没了。
motor-driven pay-off - 马达传动的放线装置 (0) 投诉
61
