首页 > 国外线缆
[问题求助] UL2037与UL20276有什么差别
P:2007-08-29 18:59:59
AWM style 20379 & 20276
UNDERWRITERS LABORATORIES INC. APPLIANCE WIRING MATERIAL
Subj. 758 Section 2 Page 20276 Issued: 1983-08-16
Revised: 2003-06-05
Style 20276 Electronic Cable.
______________________________________________________________________________
Rating 60°C or 80°C, 30 V.
Insulated No. 40 AWG minimum. Labeled or complying with AWM
Conductors Procedure having a minimum rating of 60°C or 80°C
whichever is applicable.
Assembly Consists of two or more conductors, twisted pairs,
parallel pairs, or groups of twisted conductors or
parallel pairs twisted together. The conductors or
groups of conductors may be laid parallel forming a flat,
oval or round cable. The lay of the insulated conductors
are not specified. A barrier layer and/or fillers are
optional. Manufacturer shall maintain a complete
description of each assembly. May use same or mixed AWG
size.
Covering (Optional.) A 6 mil or heavier PVC covering may be
extruded over the conductor assembly.
Shield Optional.
Jacket PVC Class 43.
Thickness (mils)
Construction A Construction B
External Use Internal Use
#Dia. under Minimum Minimum
jacket in Minimum at Minimum at
inches__ Average any Point Average any Point
0.350 or less 20 17 15 12
0.351 - 0.700 30 24 30 24
0.701 - 1.00 40 36 40 36
0.101 - 1.50 54 48 54 48
Standard Appliance Wiring Material UL 758.
(Continued on Page 20276A)
Subj. 758 Section 2 Page 20276A Issued: 1983-08-16
Revised: 2003-06-05
Instructions Detailed Examination.
to UL Physical Properties of Jacket.
Representative
The designation of all Styles of the individual
conductors used making up the cable assembly shall be
available, and the UL Representative's tag shall indicate
if the Style is labeled or not. If they are not labeled,
the appropriate Follow-Up Tests shall be conducted.
UL (4) Detailed Examination.
*Counter-Check (4) Physical Properties of Jacket.
*Program (4) Heat Shock.
* (4) Deformation.
* (4) Cold Bend.
(12) Cable Flame Test on Completed Cable,
Construction A only.
(12) Horizontal Flame Test on Completed Cable,
Construction B only.
If the insulated Styles are not labeled, the appropriate
Marking General.
Use Construction A: Internal wiring or external
interconnection of electronic equipment in Class 2
circuits only.
Construction B: Internal wiring of electronic equipment
in Class 2 circuits only.
wood pulp - 木浆 (0) 投诉
P:2007-08-29 19:03:36
Subj. 758 Section 2 Page 20379 Issued: 1985-01-31
Revised: 2003-03-31
Style 20379 PVC Jacketed Cable.
Rating 80°C, 30 Volts.
Conductors No. 50 AWG minimum. Material not specified.
Insulation Material not specified - for use Statement No. 1.
Insulated Singles Labeled or complies with manufacturer's Procedure with
minimum rating 80°C - for use Statement No. 2.
Assembly Two or more twisted singles or groups of twisted singles
twisted together or groups may be laid parallel to form
flat, oval, or round cables. May use same or mixed AWG.
Lay not specified. Barrier layer and/or fillers optional.
Manufacturer shall maintain a complete description of each
assembly.
Covering Optional. PVC, 13 mil minimum at any point or a helically
or longitudinally applied PTFE tape of 1 mil nominal
thickness (lap not specified).
Shield (Optional). May be over one or more of the
insulated conductors or applied over the assembly.
Jacket PVC
Thickness of Jacket (Mils)
Dia of Cable Minimum
Under Jacket Minimum at any
In Inches Average Point
____________ __________ ________
0.250 or less 15 13
0.251 - 0.350 22 20
0.351 - 0.424 30 27
0.425 - 0.700 60 48
(Continued on Page 20379A)
Subj. 758 Section 2 Page 20379A Issued: 1985-01-31
Revised: 2003-03-31
to UL
Representative
Counter-Check (4) Flexibility Test.
*Program (12) Horizontal Flame Test on Complete Cable,
Use No. 1 only.
* (12) Cable Flame Test on Complete Cable, Use No. 2 only.
Marking General.
Use No. 1 Internal wiring in Class 2 circuits of electronic equipment
where each end is terminated in connectors.
Use No. 2 Internal wiring in Class 2 circuits of electronic equipment
or external interconnection in Class 2 circuits of
electronic equipment where not routed along walls, floors,
or other abuse areas.
duct run - 电缆管道,管道走向 (0) 投诉
