首页 > 国外线缆
[问题求助] ul2464在ul哪个标准里的?
P:2007-08-20 20:29:07
ul2464在ul哪个标准里的?
我怎么找不到?
coloured-stripe tracer - 着色标志带 (0) 投诉
P:2007-08-21 08:51:04
UL 758 AWM STYLE 2464
Fresnel reflection - 菲涅耳反射(指具有不同折射率的两种均匀介质问的交界面上入射光的部分反射) (0) 投诉
P:2007-08-21 10:11:03
UL1581
ca - cable assembly电缆组 (0) 投诉
P:2007-08-21 13:52:03
不太明白楼主的问题
printed conductor - 印刷导线,印成导线 (0) 投诉
P:2007-08-21 15:46:17
UNDERWRITERS LABORATORIES INC.               APPLIANCE WIRING MATERIAL
Subj. 758       Section 2       Page 2464        Issued:  1968-05-02
                                    Revised:  2003-05-02
Style 2464      PVC Jacketed Cable.
______________________________________________________________________________
Rating      80°C, 300 V.
Insulated       Labeled or complying with manufacturer's AWM Procedure
Conductors      having a minimum rating of 80°C and 300 V.
Assembly        Two or more singles, twisted pairs of groups of twisted
            singles twisted together or singles or groups of singles
            may be laid parallel to form flat, oval or round cable.
            Lay not specified.  Barrier layer and/or fillers optional.
            Manufacturer shall maintain a complete description of each
            assembly.  May use same or mixed AWG size.
*Covering       (Optional.)
Shield      Optional.
Jacket      PVC - Class 43
                         THICKNESS OF PVC JACKET (mils)
            #Dia. of Cable                  Minimum
            Under Jacket        Minimum     at any
               in Inches         Average      point
            0.700 or less          30             24
            0.701 - 1.000          45             36
            1.001 - 1.500          60             48
            1.501 - 2.500          80             64
            2.501 - 4.000         110             88
            4.001 or larger        140           112
            # Major diameter if cable is flat or oval.
Braid           Optional.
Standard        Appliance Wiring Material UL 758.
                                (Continued on Page 2464A)
Subj. 758       Section 2       Page 2464A     Issued:  1968-05-02
                                   Revised:  2003-05-02
Instructions    Detailed Examination of the cable assembly and jacket.
to UL           Physical Properties of Jacket.
Representative  Dielectric Strength Test, 1500 Volts (shielded cable only).
The designation of all Styles of the individual conductors used making up the cable assembly shall be available, and the UL Representative’s tag shall indicate if the Style is labeled or not.  If they are not labeled, the appropriate Follow-Up Tests shall be conducted.
UL          (4)  Detailed Examination.
Counter-Check   (4)  Physical Properties of Jacket.
Program     (4)  Heat Shock on Jacket.
            (4)  Cold Bend on Completed Cable.
            (4)  Deformation on Jacket, Class 43.
            (12) Cable Flame Test on Completed Cable.
If the insulated styles are not labeled, the appropriate Follow-Up Tests shall be conducted.
Marking     General.
Use         Internal wiring or external interconnection of electronic
            equipment (such as desk-type calculators, dictating
            machines, or x-ray equipment).
program me - 程序;计划,方案;节目 (0) 投诉
P:2007-08-21 18:06:48
cuijiude:
758里没有下面那篇文字啊
PST - plesiochronous section termination准同步段终端 (0) 投诉
P:2007-08-22 19:43:23
在UL758的活页里
chisel bond - 凿形焊接线 (0) 投诉
P:2007-08-23 14:01:44
汗,是否沒有UL相關資料還是樓主第一次做UL線?
all-natural bonding adhesive - 全天然粘接剂 (0) 投诉
P:2007-08-23 16:33:17
cuijiude:
                                    Revised:  2003-05-02
Rating      80°C, 300 V.
Shield      Optional.
            0.700 or less          30             24
            0.701 - 1.000          45             36
            1.001 - 1.500          60             48
            1.501 - 2.500          80             64
Braid           Optional.
                                   Revised:  2003-05-02
Marking     General.
楼兄正解啊!
DICOM - digital communication数字通信 (0) 投诉
P:2007-08-27 14:09:18
就这一段理解不了,哪位高手说下
centre conductor - 中心导体(同轴电缆中的),中间导体(三线直流供电制的) (0) 投诉
P:2007-08-27 20:58:39
wanghui586:
在UL758的活页里
758一共是78页
没有这些玩意啊
cord - 软绳,软线,塞绳 (0) 投诉
P:2007-08-27 21:36:42
UL 758    ISBN 0-7629-1166-2
是不是这个?
困扰我很久了,谁给我解答下
我在pdf里搜索2464或者style
查到结果都是0
是不是我这边的758不全啊
videotex - 可视图文,可视数据,信息传视系统 (0) 投诉
P:2007-08-28 14:44:10
在活頁裏,上UL網站查www.ul.com  -certification-在SPECIFIC SEARCHES裏選擇AWM-在下面的搜索欄中輸入2426
http://iq.ul.com/stylepages/2426-AWM-Fixed.rtf
ECAP - electronic circuit analysis program电子电路分析程序 (0) 投诉
P:2007-08-28 20:19:08
谢谢
果然找到了
不过有没有办法能找到一整套的pdf
insulating compound - 绝缘混合物 (0) 投诉
P:2007-08-30 11:04:33
我有一整套的pdf,有12.5 MB大,傳不了。
solid lubricant film - 固体润滑剂薄膜 (1) 投诉
19
