首页 > 国外线缆
[问题求助] 有谁知道UL2962线材
P:2007-08-20 17:11:35
现客户有需求UL2962#26线材,以前没接触过,请有知道的指点下.越详细越好,有资料更是请提供给我先,谢谢,拜托了!
puncture test - 击穿试验 (0) 投诉
P:2007-08-21 09:55:38
UNDERWRITERS LABORATORIES INC.             APPLIANCE WIRING MATERIAL
Subj. 758      Section 2      Page 2962       Issued:  Oct. 6, 1978
                                Revised:  Feb. 15, 2001
Style 2962    Flat Cable.
______________________________________________________________________________
Rating     60, 80, 90 or 105°C, 30 Volts.
Conductors    2-100, 40 AWG min.  Material not specified.
Assembly      Extruded construction or PVC insulated wires laid
           parallel in one plane and bonded together.  May
           include mixed AWG sizes and may include maximum
           100 mils web width.
Insulation    PVC, 4 mils minimum at any point.  If rippable
           construction, measurements made after ripping.
*Shield       Optional.
*Jacket       Optional when shield is not used.  Extruded PVC, Class 43.          4 mil minimum at any point, maximum web of 100 mil.
*Standard     Appliance Wiring Material UL 758.
Instructions  Detailed Examination.
*to UL     Flexing, Unaged.
Representative
UL         (4)  Detailed Examination.
*Counter-Check    (4)  Flexing.
*Program      (4)  Horizontal Flame Test.
*Marking      General.
Use        Internal wiring of Class 2 circuits in electronic
           equipment.
reflective index - 反射率 (0) 投诉
P:2007-08-21 16:47:47
樓上的,你是在UL網站上查的嗎?
intercoat - 中间涂层 (0) 投诉
