首页 > 国外线缆
[问题求助] UL2468中是否有对摇摆进行描述,条件是什么?
P:2006-09-12 15:13:03
我刚进入线材行业,对线材的安规不太了解,请问一下UL2468中是否有对摇摆进行描述,条件是什么?
inspection test - 检查试验 (0) 投诉
P:2006-09-12 15:32:03
沒有這方面的要求的,這是一種并線吧
oil pressure cable - 油压电缆 (0) 投诉
P:2006-09-12 16:34:31
是并排线,你是否有UL2468的安规资料,请发一份给我好吗?
Email:heqy@milestome-mec.com
attrition wear - 互磨磨损 (0) 投诉
P:2006-09-12 16:41:53
应该都是客户要求的吧﹐在2468里没有摇摆要求
NAC - none attach concentrator无连接集线器 (0) 投诉
P:2006-09-12 20:10:02
什么是UL2468?俺怎么从没听说过,恕俺愚钝,请好心人指点一下.
dissolvant - 溶剂 (0) 投诉
P:2006-09-13 08:08:16
AWM 2468是并线,UL标准中无弯曲要求,次线一般用与一些家用电器的插头连接线;当然,如果客户的使用条件比较特殊,要求弯曲也可以,但客户要提供弯曲的具体条件,如摇摆频率,摆角,负重,R角,次数,这样才能做弯曲实验.
laser scan micrometer - 激光扫描测微计 (0) 投诉
P:2006-09-13 08:09:45
UL 758中的 STYLE 2468
UNDERWRITERS LABORATORIES INC. APPLIANCE WIRING MATERIAL
Subj. 758 Section 2 Page 2468 Issued: 1968-05-07
Revised: 2003-03-31
Style 2468 Flat Ribbon-Type Cable.
______________________________________________________________________________
Rating 80°C, 300 Volts.
Conductor 2-150, Nos. 32-16 AWG. Tinned or bare, solid or stranded
copper, conductors laid parallel and in one plane. Same
or mixed AWG.
*Insulation Each conductor has a nominal 15 mils wall or heavier
thermoplastic (PVC). This forms a flat cable with a
single row of conductors having a 1/2 in. maximum width
web between insulated conductors. The nominal and minimum
insulation thickness along the ripped edges for each
conductor shall be 15 and 13 mils, respectively.
Shield Optional.
Covering (Optional) PVC, 5 mils min. at any point 80 mils max.
Standard Appliance Wiring Material UL 758.
Instructions Detailed Examination.
*to UL Tensile Strength and Elongation of Insulation.
*Representative Spark Test.
UL (4) Detailed Examination.
*Counter-Check (4) Tensile Strength and Elongation of Insulation.
Program (4) Heat Shock.
(4) Cold Bend.
(4) Deformation.
(12) Horizontal Flame Test.
Marking General.
Use Internal wiring of Appliances; or internal wiring of
Appliances where exposed to oil at a tempera-ture not
exceeding 60°C or 80°C, whichever is applicable.
disc seal gland - 垫片密封盖,垫片密封压盖(电缆接头附件) (0) 投诉
P:2006-09-13 14:44:26
谢谢,各位的回复!!!!
不过还有一个问题,一般线材是参照哪个标准,是UL758还是UL1581或其它
gas fired continuous wire patenting furnace - 燃气式线材连续退火炉,燃气式线材连续拉后退火炉 (0) 投诉
P:2006-09-13 15:46:38
UL线的相关要求你可以在相应的Style page中找到哈,像 cuijiude 的回复中的就是2468的相关要求咯
里面已经提到咯 Standard        Appliance Wiring Material UL 758.
ground shield - 接地屏蔽(US) (0) 投诉
P:2006-09-14 13:51:21
摇摆测试﹐好像在ASTM中有要求﹐但我不知道是具体哪一个﹐有了解的可以回复。
optical fibre cable colour coater - 光纤光缆涂色器 (0) 投诉
P:2006-11-02 19:00:15
UL中没有对2468做出摇摆要求,一定是客户要求的,可以根据客户的要求在设计中做出调整!
UForward - 入射电压 (0) 投诉
P:2007-01-22 09:00:01
應是線套或DC頭的彎曲試驗, 它和電線插頭的結構有關
non-contact high voltage continuity tester - 非接触式高压连续性检测器,非接触式高压漆膜连续性检测器 (0) 投诉
P:2007-01-27 13:08:10
主要是針對SR及DC  PLUG  模的實驗.
應該和模具結構也有關系.
ACT - Accelerated Contamination Testing加速污秽试验 (0) 投诉
P:2007-06-24 09:52:32
吊重200g,60度,45次/分,1000次以上不断线
friction test - 摩擦试验 (0) 投诉
P:2007-07-20 15:56:53
没听过UL2468线要摇摆测试的,电子线的规格在论坛上就找得到,很多的,你耐心点找一下就可以找到
echo - 回波,反射 (0) 投诉
19
