首页 > 国外线缆
[问题求助] UL758 资料中需求wire 印字部分资料
P:2015-01-06 09:25:39
UL线缆印字在UL758和C22.2 No 210中有要求,具体可参考以下,希望有帮助!
下面是参考的UL758印字要求
50.1 Surface marking is not required for appliance wiring material.
50.2 When surface marking referencing ²AWM² is used, the marking shall contain the following elements:
a) Wire/cable designation: ²AWM.²
b) Name of the organization responsible for the AWM, trade name, other applicable mark, or
file number. When the organization responsible for the AWM produces AWM in more than one
location, an additional distinctive marking shall be provided that identifies the specific
manufacturing location of the AWM.
Other markings such as wire size, number of conductors, and similar data, are determined to be in
compliance with this requirement when they are not confusing or misleading.
50.3 For a cable that contains a conductive polymeric shield, the jacket or marker tape shall be marked
²Conductive Shield,² ²Contains Polymeric Conductive Shield,² or equivalent and the marking shall be
repeated at the following intervals throughout the entire length of the cable:
a) Markings on the outer surface of the cable shall be repeated at intervals that are not longer
than 40 in (1.0 m).
b) Information on a marker tape shall be repeated at intervals that are not longer than 25 in
(635 mm).
50.3 effective September 3, 2014
参考译文:
[qq3qww 在 2015-1-6 9:45:28 编辑过]
[qq3qww 在 2015-1-6 9:49:19 编辑过]
disturbance - 干扰;故障 (0) 投诉
感谢2楼的朋友, 很热心肠~给的都是
