首页 > 国外线缆
[问题求助] UL 83型号求解!
P:2014-10-10 14:30:12
Thermoplastic-insulated wire is rated 600 V and is designated as follows:
TW — Indicates a single conductor having flame-retardant, moisture-resistant thermoplastic insulation. The wire is rated 60°C wet or dry.
THHN — Indicates a single conductor having flame-retardant and heat-resistant thermoplastic insulation with a jacket of extruded nylon or equivalent material. The wire is rated 90°C dry only.
THW — Indicates a single conductor having flame-retardant, moisture- and heat-resistant thermoplastic insulation. The wire is rated 75°C wet or dry.
THW-2 — Same as THW except that the wire is rated 90°C wet or dry.
THHW — Indicates a single conductor having flame-retardant, moisture- and heat-resistant thermoplastic insulation. The wire is rated 90°C dry and 75°C wet.
THWN — Indicates a single conductor having flame-retardant, moisture- and heat-resistant thermoplastic insulation with a jacket of extruded nylon or equivalent material. The wire is rated 75°C wet or dry. THWN wire suitable for exposure to mineral oil and to liquid gasoline and gasoline vapors at ordinary ambient temperature is marked "Gasoline and Oil Resistant I
" if suitable for exposure to mineral oil at 60°C, or "Gasoline and Oil Resistant II
" if the compound is suitable for exposure to mineral oil at 75°C. Gasoline resistant wire has been tested at 23°C when immersed in gasoline. It is considered inherently resistant to gasoline vapors within the limits of the temperature rating.
THWN-2 — Same as THWN except that the wire is rated 90°C wet or dry.
halogens - 卤素 (0) 投诉
但6楼没有T90 Nylon和TWN75这两个型号啊?
