首页 > 国外线缆
[问题求助] 求UL1426标准
P:2007-08-08 08:13:02
UNDERWRITERS LABORATORIES, INC. APPLIANCE WIRING MATERIAL
Subj. 758 Section 1 Page 1462 Issued: 11-7-68
Style 1462 Polypropylene-Insulated, Shielded and Thermoplastic (PVC) Jacketed Cable.
____________________________________________________________________________
Rating 80 C, 600 volts (voltage rating applies to jacket only).
Conductor No. 20-26 AWG copper-clad steel, bare, tinned or silver- coated, having a minimum 40 per cent conductivity,
page 35.
Insulation Over the conductor shall be applied a spiral wrap of polypropylene thread nominally 35 mils in diameter, approximately 1/2 in. between turns. This assembly shall be enclosed with a polypropylene tube have an
Shielding A shield over the tube shall consist of a bare or tinned copper braid. A drain wire may be applied under the shield.
Jacket Thermoplastic (PVC), nominally 32 mils, minimum (at any point) 28 mils, shall be the outer jacket.
Standard Flexible Cord and Fixture Wire, UL 62.
Instructions Detailed examination.
to UL Tensile strength and elongation of jacket, Class 12, page
Representative 32. Spark test, 5000 volts, page 30, shall be applied between shielding and electrode contacting outer surface of jacket.
Counter-Check (4) Physical properties of polypropylene tube, see facing
Program page.
(4) Physical properties of jacket, Class 12 (rated 80 C).
(4) Cold Bend (applicable to jacket only), page 58.
Manufacturer's marker required, pages 3, 18, 19.
Items 1h, 3m, 4p.
Temperature marker not required.
Use In electronic equipment where exposed to a temperature
not exceeding 80 C and where the jacket is exposed to a
maximum operating potential of 600 volts.
AIA - Aluminium Industry Abstracts铝工业文摘 (0) 投诉
P:2007-08-08 14:10:17
UNDERWRITERS LABORATORIES INC. APPLIANCE WIRING MATERIAL
Subject 758 Section 1 Page 1426 Issued: Feb. 8, 1967
Style 1426 Polyvinylidene Fluoride Resin Insulated Wire
______________________________________________________________________________
Rating
*Conductor No. 32-20 AWG.
Insulation 6 Mils min average, 5 mils min at any point wall
polyvinylidene fluoride resin.
*Standard Appliance Wiring Material UL 758.
*to UL Flexing, except using mandrel two times diameter of wire.
*Representative Spark Test, 2,000 volts.
Tensile strength and elongation, as received, (4500 psi and
100 per cent elongation, minimum acceptable values).
UL (4) Detailed examination.
Counter-Check (2) Age 60 days in air-oven at
*Program shall be flexed as described on except using
(4) Tensile strength and elongation, same as above.
* (4) Horizontal Flame Test.
*Marking General.
Use In back panel areas of electronic computers and business
machines where not subjected to movement or mechanical
damage.
single-bunch bunch stranded conductor - 单束束绞线芯 (0) 投诉
